Certificate request failure for searxng docker container with reverse proxy
Greetings, first time here and error that I can not resolve on my own...
  • searxng.pl4.fi (Not working)
  • nc.pl4.fi (working)
    Both have same public IP as service are behind Nginx reverse proxy.
root@vhost03 ~ # certbot --nginx -d searx.pl4.fi -v
Attempting to parse the version 2.11.0 renewal configuration file found at /etc/letsencrypt/renewal/nc.pl4.fi.conf with version 1.21.0 of Certbot. This might not work.
Requesting a certificate for searx.pl4.fi
http-01 challenge for searx.pl4.fi
Challenge failed for domain searx.pl4.fi
Domain: searx.pl4.fi
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for searx.pl4.fi - check that a DNS record exists for this domain; no valid AAAA records found for searx.pl4.fi
root@vhost03 ~ # nginx -v
nginx version: nginx/1.18.0 (Ubuntu)
root@vhost03 ~ # hostnamectl
Static hostname: vhost03
Icon name: computer-desktop
Chassis: desktop
Machine ID: e824e778f73b4c479bc91de012d88709
Boot ID: d404da808f7947f593e95bd43f76a1d9
Operating System: Ubuntu 22.04.4 LTS
Kernel: Linux 5.15.0-119-generic
Architecture: x86-64
Hardware Vendor: ASUSTeK COMPUTER INC.
Hardware Model: System Product Name
Well I can start Cockpit on machine if needed (Service is masked currently).
root@vhost03 ~ # certbot --version
certbot 1.21.0
Other info:
nginx sites-enabled file
root@vhost03 ~ # cat /etc/nginx/sites-enabled/searx.pl4.fi
server_name srx.pl4.fi;
    proxy_pass http://192.168.103.102:8080;
    include proxy_params;
    proxy_set_header X-Forwarded-For $remote_addr;
    proxy_set_header X-Forwarded-Host $host;
    proxy_buffering off;
    proxy_read_timeout 90;
    proxy_connect_timeout 90;
    proxy_send_timeout 90;
server_name searx.pl4.fi;
DNS query from another machine
jmoilanen@dkp01:~$ dig searx.pl4.fi @8.8.8.8
; <<>> DiG 9.18.28-0ubuntu0.22.04.1-Ubuntu <<>> searx.pl4.fi @8.8.8.8
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 34269
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 512
;; QUESTION SECTION:
;searx.pl4.fi. IN A
;; AUTHORITY SECTION:
pl4.fi. 5 IN SOA ns1.dy.fi. hostmaster.dy.fi. 31 1800 3600 604800 5
;; Query time: 50 msec
;; SERVER: 8.8.8.8#53(8.8.8.8) (UDP)
;; WHEN: Sun Aug 25 20:50:37 EEST 2024
;; MSG SIZE rcvd: 95
Others:
Nginx is up and running and also nginx -t gives following answer:
root@vhost03 ~ # nginx -t
nc.pl4.fi shows up nextcloud as it should be.
searx.pl4.fi shows searxng search (without SSL ofc).
What should I look next? Any ideas?
You have two name servers but only one of them returns an A record. Let's Encrypt needs all of them to return the correct reply as it may query any of them.
Check your ns2 server. You can reproduce by repeatedly running https://unboundtest.com query for your A record
From my own machine I get no reply from ns2
dig +noall +answer searx.pl4.fi @ns2.dy.fi
dig +noall +answer searx.pl4.fi @ns1.dy.fi
searx.pl4.fi.           30      IN      A       95.217.73.32
Thanks a lot. That was fast! It seems that dy.fi have some problems with their DNS servers (Free DDNS provider) so I need to contact them.
As I side note, any cheap DNS providers that anyone would suggest?
Cloudflare :slight_smile: Free and well-integrated with variety of ACME Clients. Good docs and community too
Or have a look in this former Wiki thread: DNS providers who easily integrate with Let's Encrypt DNS validation
That said, that time I wanted to have a free DNS provider with good Certbot integration, I also have good experience with CF.
