Certificate renewed without challenge?
Running certbot with --manual-auth-hook true (or cat) renewed my wildcard cert without any challenge/authentication.
My domain is: *.goldstein.rs
I ran this command: sudo certbot renew --manual --preferred-challenges=dns --force-renewal --manual-auth-hook true
Processing /etc/letsencrypt/renewal/goldstein.rs.conf
Renewing an existing certificate for *.goldstein.rs
new certificate deployed without reload, fullchain is
/etc/letsencrypt/live/goldstein.rs/fullchain.pem
Congratulations, all renewals succeeded:
/etc/letsencrypt/live/goldstein.rs/fullchain.pem (success)
The operating system my web server runs on is (include version): Linux srvr 5.10.6-arch1-1 #1 SMP PREEMPT Sat, 09 Jan 2021 18:22:35 +0000 x86_64 GNU/Linux
My hosting provider, if applicable, is: Hetzner
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.12.0
Welcome to the Let's Encrypt Community :slightly_smiling_face:
Since your last certificate was issued less than 30 days ago, the authorization was still cached and thus no challenge was needed.
--manual-auth-hook requires a script to be given afterwards, not a boolean value.
You might want to consider including goldstein.rs in you certificate (like you did back in December) as *.goldstein.rs does not cover it.
https://crt.sh/?Identity=goldstein.rs&deduplicate=Y
true is not a boolean value, it's a shell command that does nothing.
So if I renew cert every 3 weeks I never need to pass challenge?
No, renewing without actually getting a new valid authorization doesn't magically "reset" the validation date of the cached authorization. The cached authorization will still expire 30 days after it was ("initially") validated and a new authorization will be necessary, regardless of renewals in between.
Nope.
The cache expires around 4 weeks after the challange was passed the first time.
