Certificate renewal issue
My domain is: laradenaro.com & www.laradenaro.com
I ran this command: sudo certbot certonly --webroot -w /var/www/html -d laradenaro.com --dry-run
Blockquote
Simulating a certificate request for laradenaro.com
http-01 challenge for laradenaro.com
Using the webroot path /var/www/html for all unmatched domains.
Challenge failed for domain laradenaro.com
    Domain: laradenaro.com
    Detail: 2001:4860:4802:36::15: Invalid response from
    https://www.laradenaro.com: "<html
    lang="en-gb"><meta charset="utf-8"><meta
    http-equiv="X-UA-Compatible" content="IE=edge"><meta name="v"
Blockquote
My web server is (include version): nginx 1.18.0-6.1
The operating system my web server runs on is (include version): Rasbian 11 32 bit
My hosting provider, if applicable, is: n/a
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.12.0
I'm not quite certain whether I have a problem here or not! When I initially set up the server I got two certificates: laradenaro.com and www.laradenaro.com. On attempting to renew, laradenaro.com fails but www.laradenaro.com succeeds. The output of "cerbot certificates' now gives me:
Blockquote
Found the following certs:
Certificate Name: laradenaro.com
Serial Number: 3760162092d15ddb336723c08259ef02d75
Key Type: RSA
Domains: laradenaro.com www.laradenaro.com
Expiry Date: 2022-06-20 10:00:40+00:00 (VALID: 3 days)
Certificate Path: /etc/letsencrypt/live/laradenaro.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/laradenaro.com/privkey.pem
Certificate Name: www.laradenaro.com
Serial Number: 3cf64476a8d5da34466034c6f62d63edfa3
Key Type: RSA
Domains: www.laradenaro.com
Expiry Date: 2022-09-14 10:55:27+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/www.laradenaro.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/www.laradenaro.com/privkey.pem
Blockquote
I wonder if it is something to do with a redirect from laradenaro.com to www.laradenaro.com? The question is: am I likely to have a problem in 3 days time or will the single new certificate suffice? Any advice much appreciated :slight_smile:
Hi @ken30, and welcome to the LE community forum :slight_smile:
Yes, I think it is.
Addresses: 2001:4860:4802:34::15
           2001:4860:4802:38::15
           2001:4860:4802:32::15
           216.239.34.21
           216.239.36.21
           216.239.38.21
           216.239.32.21
Address: 81.131.95.46
Try:
sudo certbot renew
OR
sudo certbot certonly --webroot -w /var/www/html -d www.laradenaro.com
If either succeeds, show:
certbot certificates
Many thanks for the rapid reply.
certbot renew fails for laradenaro.com but shows www.laradenaro.com as previously renewed.
certbot certonly (as a dry-run) similarly fails for laradenaro.com but is successful for www.laradenaro.com.
The output of certbot certificates is:
Key Type: RSA
Key Type: RSA
OK.
You have a choice:
  • use the second cert for the "www" name only
    [and delete the first cert]
  • undo the redirection at the domain registrar
    then renew the first cert and use both names
    [and you do the redirection yourself within the server and delete the second cert]
Thanks for the advice - I'll do the latter.
To delete the second cert use:
certbot delete --cert-name www.laradenaro.com
