My domain is: velebittravel.com
I ran this command: sudo certbot --nginx
blank to select all options shown (Enter 'c' to cancel): 2
Requesting a certificate for velebittravel.com
http-01 challenge for velebittravel.com
Challenge failed for domain velebittravel.com
Domain: velebittravel.com
Detail: Invalid response from http://www.velebittravel.com
[144.217.153.176]: "<html xml:lang=\"fr-FR\"
lang=\"fr-FR\">\n<head>\n<title qtlid=\"28806\">Félicitations !
Votre domaine a bien été créé chez OVH !</"
My web server is (include version): NGINX 1.18.0
The operating system my web server runs on is (include version): CentOS 7
My hosting provider, if applicable, is: OVH (A VPS)
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): VestaCP
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): Certbot 1.10.1
rg305
January 12, 2021, 1:11am
2
Hi and welcome to the LE community forum
You showed that you selected "2", but you don't show what they are:
I see that you want to get a cert for domain: velebittravel.com
But the failure is for:
With the "WWW".
I also see that the first domain redirects to the second:
curl -Iki velebittravel.com
HTTP/1.1 302 Moved Temporarily
Server: nginx
Date: Tue, 12 Jan 2021 01:05:30 GMT
Content-Type: text/html
Content-Length: 138
This may be part of the problem.
If your config isn't prepared to handle the challenge requests correctly.
If I may advise, I would get a cert with both names on it.
Then you can also correctly redirect HTTPS requests to the WWW.
As for the "proper handling", I've found it best to handle the HTTP challenges in HTTP.
[With some creative coding]
If you are willing to share your vhost configs, maybe we can adjust them to suit all your needs.
Well, so how do i get the cert for the both name? And how do i solve this problem?
The 2 domains i was selecting were the www.velebittravel.com and velebittravel.com .
I don't know how get you the vhost settings nor what do you mean with it.
rg305
January 12, 2021, 1:31am
4
This answers that:
[you chose correctly for that]
Please post the output of:
[I suspect it wont be too long]
nginx -T
Be sure to use three backticks above and below your config - or it may be difficult to read.
Like this:
your config
your config
your config
This it what it says, but it still giving me the same error.
rg305
January 12, 2021, 2:19am
6
NOT:
nginx -t
please show
ningx -T
[with a CAPITAL "T"]
Oh sorry, there you are
root@www:~# nginx -T
# Server globals
user www-data;
worker_processes auto;
worker_rlimit_nofile 65535;
pid /var/run/nginx.pid;
# Worker config
events {
worker_connections 1024;
use epoll;
multi_accept on;
http {
# Main settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
client_header_timeout 60s;
client_body_timeout 60s;
client_header_buffer_size 2k;
client_body_buffer_size 256k;
client_max_body_size 256m;
large_client_header_buffers 4 8k;
send_timeout 60s;
keepalive_timeout 30s;
reset_timedout_connection on;
server_tokens off;
server_name_in_redirect off;
server_names_hash_max_size 512;
server_names_hash_bucket_size 512;
# Log format
log_format main '$remote_addr - $remote_user [$time_local] $request '
'"$status" $body_bytes_sent "$http_referer" '
'"$http_user_agent" "$http_x_forwarded_for"';
log_format bytes '$body_bytes_sent';
#access_log /var/log/nginx/access.log main;
access_log off;
# Mime settings
# Compression
gzip on;
gzip_static on;
gzip_vary on;
gzip_comp_level 6;
gzip_min_length 1024;
gzip_buffers 16 8k;
gzip_types text/plain text/css text/javascript text/js text/xml application/json application/javascript application/x-javascript application/xml application/xml+rss application/x-font-ttf image/svg+xml font/opentype;
gzip_proxied any;
gzip_disable "MSIE [1-6]\.";
# Proxy settings
proxy_redirect off;
proxy_set_header Host $host;
proxy_pass_header Set-Cookie;
proxy_buffers 32 4k;
proxy_connect_timeout 30s;
proxy_send_timeout 90s;
proxy_read_timeout 90s;
# Cloudflare https://www.cloudflare.com/ips
set_real_ip_from 103.21.244.0/22;
set_real_ip_from 103.22.200.0/22;
set_real_ip_from 103.31.4.0/22;
set_real_ip_from 104.16.0.0/12;
set_real_ip_from 108.162.192.0/18;
set_real_ip_from 131.0.72.0/22;
set_real_ip_from 141.101.64.0/18;
set_real_ip_from 162.158.0.0/15;
set_real_ip_from 172.64.0.0/13;
set_real_ip_from 173.245.48.0/20;
set_real_ip_from 188.114.96.0/20;
set_real_ip_from 190.93.240.0/20;
set_real_ip_from 197.234.240.0/22;
set_real_ip_from 198.41.128.0/17;
#set_real_ip_from 2400:cb00::/32;
#set_real_ip_from 2606:4700::/32;
#set_real_ip_from 2803:f800::/32;
#set_real_ip_from 2405:b500::/32;
#set_real_ip_from 2405:8100::/32;
#set_real_ip_from 2c0f:f248::/32;
#set_real_ip_from 2a06:98c0::/29;
real_ip_header CF-Connecting-IP;
# SSL PCI Compliance
ssl_session_cache shared:SSL:10m;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_prefer_server_ciphers on;
ssl_ciphers "ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA256:ECDHE-RSA-AES256-SHA:ECDHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES128-SHA256:DHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES256-GCM-SHA384:AES128-GCM-SHA256:AES256-SHA256:AES128-SHA256:AES256-SHA:AES128-SHA:DES-CBC3-SHA:HIGH:!aNULL:!eNULL:!EXPORT:!DES:!MD5:!PSK:!RC4";
# Error pages
error_page 403 /error/403.html;
error_page 404 /error/404.html;
error_page 502 503 504 /error/50x.html;
# Cache settings
proxy_cache_path /var/cache/nginx levels=2 keys_zone=cache:10m inactive=60m max_size=1024m;
proxy_cache_key "$host$request_uri $cookie_user";
proxy_temp_path /var/cache/nginx/temp;
proxy_ignore_headers Expires Cache-Control;
proxy_cache_use_stale error timeout invalid_header http_502;
proxy_cache_valid any 1d;
# Cache bypass
map $http_cookie $no_cache {
default 0;
~SESS 1;
~wordpress_logged_in 1;
# File cache settings
open_file_cache max=10000 inactive=30s;
open_file_cache_valid 60s;
open_file_cache_min_uses 2;
open_file_cache_errors off;
# Wildcard include
types {
text/html html htm shtml;
text/css css;
text/xml xml;
image/gif gif;
image/jpeg jpeg jpg;
application/javascript js;
application/atom+xml atom;
application/rss+xml rss;
text/mathml mml;
text/plain txt;
text/vnd.sun.j2me.app-descriptor jad;
text/vnd.wap.wml wml;
text/x-component htc;
image/png png;
image/svg+xml svg svgz;
image/tiff tif tiff;
image/vnd.wap.wbmp wbmp;
image/webp webp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
font/woff woff;
font/woff2 woff2;
application/java-archive jar war ear;
application/json json;
application/mac-binhex40 hqx;
application/msword doc;
application/pdf pdf;
application/postscript ps eps ai;
application/rtf rtf;
application/vnd.apple.mpegurl m3u8;
application/vnd.google-earth.kml+xml kml;
application/vnd.google-earth.kmz kmz;
application/vnd.ms-excel xls;
application/vnd.ms-fontobject eot;
application/vnd.ms-powerpoint ppt;
application/vnd.oasis.opendocument.graphics odg;
application/vnd.oasis.opendocument.presentation odp;
application/vnd.oasis.opendocument.spreadsheet ods;
application/vnd.oasis.opendocument.text odt;
application/vnd.openxmlformats-officedocument.presentationml.presentation
pptx;
application/vnd.openxmlformats-officedocument.spreadsheetml.sheet
xlsx;
application/vnd.openxmlformats-officedocument.wordprocessingml.document
docx;
application/vnd.wap.wmlc wmlc;
application/x-7z-compressed 7z;
application/x-cocoa cco;
application/x-java-archive-diff jardiff;
application/x-java-jnlp-file jnlp;
application/x-makeself run;
application/x-perl pl pm;
application/x-pilot prc pdb;
application/x-rar-compressed rar;
application/x-redhat-package-manager rpm;
application/x-sea sea;
application/x-shockwave-flash swf;
application/x-stuffit sit;
application/x-tcl tcl tk;
application/x-x509-ca-cert der pem crt;
application/x-xpinstall xpi;
application/xhtml+xml xhtml;
application/xspf+xml xspf;
application/zip zip;
application/octet-stream bin exe dll;
application/octet-stream deb;
application/octet-stream dmg;
application/octet-stream iso img;
application/octet-stream msi msp msm;
audio/midi mid midi kar;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
audio/x-realaudio ra;
video/3gpp 3gpp 3gp;
video/mp2t ts;
video/mp4 mp4;
video/mpeg mpeg mpg;
video/quicktime mov;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-asf asx asf;
video/x-ms-wmv wmv;
video/x-msvideo avi;
# configuration file /etc/nginx/conf.d/51.222.141.219.conf:
listen 51.222.141.219:80 default;
server_name _;
#access_log /var/log/nginx/51.222.141.219.log main;
proxy_pass http://51.222.141.219:8080;
# configuration file /etc/nginx/conf.d/status.conf:
listen 127.0.0.1:8084 default;
server_name _;
stub_status on;
access_log off;
# configuration file /etc/nginx/conf.d/vesta.conf:
include /home/admin/conf/web/velebittravel.com.nginx.conf;
# configuration file /home/admin/conf/web/velebittravel.com.nginx.conf:
listen 51.222.141.219:80;
server_name velebittravel.com www.velebittravel.com;
error_log /var/log/apache2/domains/velebittravel.com.error.log error;
location ~* ^.+\.(jpg|jpeg|gif|png|ico|svg|css|zip|tgz|gz|rar|bz2|doc|xls|exe|pdf|ppt|txt|odt|ods|odp|odf|tar|wav|bmp|rtf|js|mp3|avi|mpeg|flv|html|htm)$ {
root /home/admin/web/velebittravel.com/public_html;
access_log /var/log/apache2/domains/velebittravel.com.log combined;
access_log /var/log/apache2/domains/velebittravel.com.bytes bytes;
expires max;
try_files $uri @fallback;
location /error/ {
alias /home/admin/web/velebittravel.com/document_errors/;
location @fallback {
location ~ /\.ht {return 404;}
location ~ /\.svn/ {return 404;}
location ~ /\.git/ {return 404;}
location ~ /\.hg/ {return 404;}
location ~ /\.bzr/ {return 404;}
include /home/admin/conf/web/nginx.velebittravel.com.conf*;
rg305
January 12, 2021, 2:29am
8
Can you please edit the post and add the backticks?
before
and after
You can click the PENCIL icon to edit.
rg305
January 12, 2021, 2:33am
9
Please show this file:
[again, use ``` before and after]
expires max;
location /error/ {
/home/admin/conf/web/velebittravel.com.nginx.conf (END)
rg305
January 12, 2021, 2:35am
11
Please show w/e this includes:
Or
remove if not needed/used.
So i just delete that line from the file?
rg305
January 12, 2021, 2:37am
14
Does that show anything?
ls -l /home/admin/conf/web/nginx.velebittravel.com.conf*
Yes, there it is
-rw-r--r-- 1 root root 147 Jan 12 02:24 /home/admin/conf/web/nginx.velebittravel.com.conf_letsencrypt
rg305
January 12, 2021, 2:39am
16
Show file:
location ~ "^/\.well-known/acme-challenge/(.*)$" {
default_type text/plain;
return 200 "$1.RR-Gy5jQRGHRWGyTwFOuarOpGypGIQC2jlSK4fDChWw";
rg305
January 12, 2021, 2:41am
18
Interesting...
That should have been removed after last use.
[something went wrong]
Let's see if we can code a more permanent solution .
and you can delete that file and that include line.
So, i must delete this:
and this line? include /home/admin/conf/web/nginx.velebittravel.com.conf*
rg305
January 12, 2021, 2:55am
20
Here I cleaned it up a tiny bit and reordered it in a way that makes more sense (top-down).
Separated the nested location out.
Added the section to handle the challenge files locally.
NOTE: You must create the path for the files to be places into.
use:
mkdir /whatever/unique/path/you/chose/
location /error/ {
}# location
}# location
expires max;
try_files $uri @fallback 404; #### added 404 as third option ####
}# location
location ~ /.well-known/acme-challenge/ {
root /your/challenge/location/; ############ This path needs to be changed and created ##########
}# location
}# location
}# server
i don't understand. That is the file that had the include sentence? May i just put it in the one that already exist?
So, then i must get my certification?
