Certificate not issued for my domain
Hello everyone!
My domain is: alleksy.com
I ran this command: sudo certbot --nginx -d alleksy.com -d www.alleksy.com
http-01 challenge for alleksy.com
http-01 challenge for www.alleksy.com
Failed authorization procedure. alleksy.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://alleksy.com/.well-known/acme-challenge/gao-M-6_WGAAvAlTFkpwHdg-BKdBM3ZzpnJE1i3Rtk0 [2a03:b0c0:1:d0::bbc:9001]: "<html>\r\n<head><title>404 Not Found</title></head>\r\n<body bgcolor=\"white\">\r\n<center><h1>404 Not Found</h1></center>\r\n<hr><center>", www.alleksy.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.alleksy.com/.well-known/acme-challenge/ReK37yw4oAnCJsd9ZBR18ZGpspQhU1hgbA7d5MXQONI [2a03:b0c0:1:d0::bbc:9001]: "<html>\r\n<head><title>404 Not Found</title></head>\r\n<body bgcolor=\"white\">\r\n<center><h1>404 Not Found</h1></center>\r\n<hr><center>"
  Domain: alleksy.com
  Type:   unauthorized
  Detail: Invalid response from
    Domain: www.alleksy.com
    Type:   unauthorized
My web server is (include version): nginx/1.14.0 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 18.04.3 (LTS) x64
My hosting provider, if applicable, is: digital ocean
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
Also, here is mine DNS A/AAAA records:
IPv6 is also correct (this records provided by Digital Ocean)
TTL everywhere is 3600
Could you help to find an error? What do I do wrong? Command I run worked on the other server, but not here
try running sudo certbot --nginx -- what does it say?
I suspect your nginx config is somewhat incomplete, ie: some missing or incomplete|wrong server_name directive.
Hi @iamalleksy
checking your domain - https://check-your-website.server-daten.de/?q=alleksy.com
You have ipv4 and ipv6. But both sends the same content, /.well-known/acme-challenge/random-filename - both with a http status 404 - Not Found.
So your ipv4/ipv6 looks good.
What says
nginx -T
1: alleksy.com
2: www.alleksy.com
Failed authorization procedure. www.alleksy.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.alleksy.com/.well-known/acme-challenge/bMdUZwfga8eLY8v-kNwIfSBZv_KMhj-TKVqeY0uNG4w [2a03:b0c0:1:d0::bbc:9001]: "<html>\r\n<head><title>404 Not Found</title></head>\r\n<body bgcolor=\"white\">\r\n<center><h1>404 Not Found</h1></center>\r\n<hr><center>", alleksy.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://alleksy.com/.well-known/acme-challenge/FO2s1JAHwUUCxp3MdVe_WDUl6fw42Sy0TsDC1iXBssI [2a03:b0c0:1:d0::bbc:9001]: "<html>\r\n<head><title>404 Not Found</title></head>\r\n<body bgcolor=\"white\">\r\n<center><h1>404 Not Found</h1></center>\r\n<hr><center>"
  Type:   unauthorized
    Domain: alleksy.com
    Type:   unauthorized
It has very big output :smiley:
it should be several hundred to few thousand lines, it’s expected.
Critical: Duplicated combinations of port and server_name.
Hm, what should I fix?
