"Certificate name mismatch" and certificate installation errors -- help! :-)
My domain is: wealthychef.net
certbot-auto --apache
It produced the below output. The logfile output is also useful and included below. It’s looong. But I think it’s important to include it all.
1: wealthychef.net
2: blog.wealthychef.net
3-5: (redacted)
6: www.wealthychef.net
blank to select all options shown (Enter ‘c’ to cancel):
Cert not yet due for renewal
You have an existing certificate that has exactly the same domains or certificate name you requested and isn’t close to expiry.
(ref: /etc/letsencrypt/renewal/wealthychef.net.conf)
What would you like to do?
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 1
Created an SSL vhost at /etc/apache2/sites-available/wealthychef.net-le-ssl.conf
Deploying Certificate to VirtualHost /etc/apache2/sites-available/wealthychef.net-le-ssl.conf
Enabling available site: /etc/apache2/sites-available/wealthychef.net-le-ssl.conf
An unexpected error occurred:
ValueError: Unable to set value to path!
  • Unable to install the certificate
    /etc/letsencrypt/live/wealthychef.net/fullchain.pem
    /etc/letsencrypt/live/wealthychef.net/privkey.pem
    Your cert will expire on 2019-05-01. To obtain a new or tweaked
    version of this certificate in the future, simply run certbot-auto
    again with the “certonly” option. To non-interactively renew all
    of your certificates, run “certbot-auto renew”
Here are the logfile contents, which I have to paste because I’m not allowed to upload attachments, apologies:
2019-01-31 00:49:49,180:DEBUG:certbot.main:certbot version: 0.30.2
2019-01-31 00:49:49,181:DEBUG:certbot.main:Arguments: [’–apache’]
2019-01-31 00:49:49,181:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#manual,PluginEntryPoint#nginx,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2019-01-31 00:49:49,198:DEBUG:certbot.log:Root logging level set at 20
2019-01-31 00:49:49,198:INFO:certbot.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2019-01-31 00:49:49,199:DEBUG:certbot.plugins.selection:Requested authenticator apache and installer apache
2019-01-31 00:49:49,309:DEBUG:certbot_apache.configurator:Apache version is 2.4.10
2019-01-31 00:49:49,855:DEBUG:certbot.plugins.selection:Single candidate plugin: * apache
Description: Apache Web Server plugin
Interfaces: IAuthenticator, IInstaller, IPlugin
Entry point: apache = certbot_apache.entrypoint:ENTRYPOINT
Initialized: <certbot_apache.override_debian.DebianConfigurator object at 0x7f4936c09d90>
Prep: True
2019-01-31 00:49:49,856:DEBUG:certbot.plugins.selection:Selected authenticator <certbot_apache.override_debian.DebianConfigurator object at 0x7f4936c09d90> and installer <certbot_apache.override_debian.DebianConfigurator object at 0x7f4936c09d90>
2019-01-31 00:49:49,856:INFO:certbot.plugins.selection:Plugins selected: Authenticator apache, Installer apache
2019-01-31 00:49:49,861:DEBUG:certbot.main:Picked account: <Account(RegistrationResource(body=Registration(status=None, terms_of_service_agreed=None, agreement=None, only_return_existing=None, contact=(), key=None, external_account_binding=None), uri=u’https://acme-v02.api.letsencrypt.org/acme/acct/50584716’, new_authzr_uri=None, terms_of_service=None), 7e4ec05be372a305649db45f54356b9a, Meta(creation_host=u’linode.richcook.net’, creation_dt=datetime.datetime(2019, 1, 31, 7, 45, 18, tzinfo=)))>
2019-01-31 00:49:49,863:DEBUG:acme.client:Sending GET request to https://acme-v02.api.letsencrypt.org/directory.
2019-01-31 00:49:49,865:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): acme-v02.api.letsencrypt.org:443
2019-01-31 00:49:49,998:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 “GET /directory HTTP/1.1” 200 658
2019-01-31 00:49:49,999:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 658
X-Frame-Options: DENY
Expires: Thu, 31 Jan 2019 08:49:49 GMT
Cache-Control: max-age=0, no-cache, no-store
Pragma: no-cache
Date: Thu, 31 Jan 2019 08:49:49 GMT
“BEQZQaQMJsQ”: “Adding random entries to the directory”,
“keyChange”: “https://acme-v02.api.letsencrypt.org/acme/key-change”,
“meta”: {
“caaIdentities”: [
“letsencrypt.org”
“termsOfService”: “https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf”,
“website”: “https://letsencrypt.org”
“newAccount”: “https://acme-v02.api.letsencrypt.org/acme/new-acct”,
“newNonce”: “https://acme-v02.api.letsencrypt.org/acme/new-nonce”,
“newOrder”: “https://acme-v02.api.letsencrypt.org/acme/new-order”,
“revokeCert”: “https://acme-v02.api.letsencrypt.org/acme/revoke-cert”
2019-01-31 00:50:01,970:INFO:certbot.renewal:Cert not yet due for renewal
2019-01-31 00:50:14,133:INFO:certbot.main:Keeping the existing certificate
2019-01-31 00:50:14,134:DEBUG:certbot.reporter:Reporting to user: Congratulations! Your certificate and chain have been saved at:
Your cert will expire on 2019-05-01. To obtain a new or tweaked version of this certificate in the future, simply run certbot-auto again with the “certonly” option. To non-interactively renew all of your certificates, run “certbot-auto renew”
2019-01-31 00:50:14,148:INFO:certbot_apache.configurator:Created an SSL vhost at /etc/apache2/sites-available/wealthychef.net-le-ssl.conf
2019-01-31 00:50:14,157:DEBUG:certbot.reverter:Creating backup of /etc/apache2/sites-available/wealthychef.net-le-ssl.conf
2019-01-31 00:50:14,284:INFO:certbot_apache.configurator:Deploying Certificate to VirtualHost /etc/apache2/sites-available/wealthychef.net-le-ssl.conf
2019-01-31 00:50:14,285:INFO:certbot_apache.override_debian:Enabling available site: /etc/apache2/sites-available/wealthychef.net-le-ssl.conf
2019-01-31 00:50:14,315:INFO:certbot_apache.configurator:Created an SSL vhost at /etc/apache2/sites-available/wealthychef.net-le-ssl.conf
2019-01-31 00:50:14,457:INFO:certbot_apache.configurator:Deploying Certificate to VirtualHost /etc/apache2/sites-available/wealthychef.net-le-ssl.conf
2019-01-31 00:50:14,492:INFO:certbot_apache.configurator:Created an SSL vhost at /etc/apache2/sites-available/wealthychef.net-le-ssl.conf
2019-01-31 00:50:14,642:INFO:certbot_apache.configurator:Deploying Certificate to VirtualHost /etc/apache2/sites-available/wealthychef.net-le-ssl.conf
2019-01-31 00:50:14,680:INFO:certbot_apache.configurator:Created an SSL vhost at /etc/apache2/sites-available/wealthychef.net-le-ssl.conf
2019-01-31 00:50:14,840:INFO:certbot_apache.configurator:Deploying Certificate to VirtualHost /etc/apache2/sites-available/wealthychef.net-le-ssl.conf
2019-01-31 00:50:14,884:INFO:certbot_apache.configurator:Created an SSL vhost at /etc/apache2/sites-available/wealthychef.net-le-ssl.conf
2019-01-31 00:50:15,065:INFO:certbot_apache.configurator:Deploying Certificate to VirtualHost /etc/apache2/sites-available/wealthychef.net-le-ssl.conf
2019-01-31 00:50:15,151:DEBUG:certbot.error_handler:Encountered exception:
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/client.py”, line 516, in deploy_certificate
fullchain_path=fullchain_path)
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot_apache/configurator.py”, line 334, in deploy_cert
vhosts = self.choose_vhosts(domain)
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot_apache/configurator.py”, line 358, in choose_vhosts
return [self.choose_vhost(domain, create_if_no_ssl)]
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot_apache/configurator.py”, line 542, in choose_vhost
self._add_servername_alias(target_name, vhost)
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot_apache/configurator.py”, line 1449, in _add_servername_alias
self.parser.add_dir(vh_path, “ServerAlias”, target_name)
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot_apache/parser.py”, line 329, in add_dir
self.aug.set(aug_conf_path + “/directive[last() + 1]”, directive)
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/augeas.py”, line 187, in set
raise ValueError(“Unable to set value to path!”)
2019-01-31 00:50:15,151:DEBUG:certbot.error_handler:Calling registered functions
2019-01-31 00:50:15,152:DEBUG:certbot.reporter:Reporting to user: Unable to install the certificate
2019-01-31 00:50:15,153:DEBUG:certbot.log:Exiting abnormally:
File “/opt/eff.org/certbot/venv/bin/letsencrypt”, line 11, in
sys.exit(main())
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/main.py”, line 1364, in main
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/main.py”, line 1125, in run
_install_cert(config, le_client, domains, new_lineage)
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/main.py”, line 759, in _install_cert
path_provider.cert_path, path_provider.chain_path, path_provider.fullchain_path)
2019-01-31 00:50:15,153:ERROR:certbot.log:An unexpected error occurred:
(EOF)
Package: apache2 2.4.10-10+deb8u13
Debian 8 Jesse
linode
no
certbot 0.30.2
:worried: . Looks like Certbot is not managing to properly understand your Apache configuration.
There's an issue open about this and the best workaround seems to be to split up your Apache virtual hosts into all separate files.
This workaround might also work, to try install them one domain at a time:
certbot-auto --apache -d wealthychef.net
Thank you, you are correct, your modification to the command fixed what I wanted, going domain by domain.
