I run a certbot
My domain is: demo.wellcast-roi.com
I tried to access https://demo.wellcast-roi.com, but it shows me that certificate is not valid.
I run at APACHE server at Centos 7.
How can we fix this?
I run a certbot
You are using a certificate from the Let's Encrypt Staging system. It is great you used that to test but you must get a production certificate for actual use. See your cert details here:
How did you obtain the certificate? Please answer as much as you can from the form you were shown
Thanks, here it is...
I ran this command: certbot certonly -a manual -d demo.wellcast-roi.com --preferred-challenges dns --staging
OUTPUT I do not have here, but we can get certificates.
My Web server is: Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips
My server is running: CentOS Linux release 7.9.2009 (Core)
My hosting provider, if applicable, is GCP
I can login to a root shell on my machine
The version of my client is certbot 1.11.0
Re-run the command without --staging to get a production cert
Thanks for your help. It is work!
