Certificate installed and showing up as invalid
My domain is: https://weye.com.br
I ran this command: Default apache instalation, although I ran the command more than one time for the same website and I changed the url from http to https between them
It produced this output: Congratulations! You have successfully enabled https://weye.com.br
My web server is (include version): ?
The operating system my web server runs on is (include version): ubuntu 14.04.05
My hosting provider, if applicable, is: amazon
So what exactly is the problem? Your site is serving a valid, trusted certificate:
https://www.ssllabs.com/ssltest/analyze.html?d=weye.com.br&hideResults=on
He might have a cache problem… (Browser side)
Might need to refresh his cache…
this is the problem, I’ll try cleaning the cache
tried many forms of cleaning but the invalid certificate error still shows up
NET::ERR_CERT_COMMON_NAME_INVALID
this is the error message showing on chrome
Hi @direclaw
calling http://weye.com.br, there is a redirect to https://weye.com.br/ and a second redirect to https://www.weye.com.br/
But your certificate has only one name weye.com.br -> this is a mismatch.
So add two names - weye.com.br and www.weye.com.br
Okay…
The issue is you only get the certificate contains .br domain, not it’s www version.
What platforms did you use to obtain the certificate?
Are you using certbot?
Thank you
yes I used certbot. what does .br names has to do with it?
the www name does not show up as an option when I use the command
sudo certbot --apache
sorry, I missed it completely, thank you
You could use this command:
sudo certbot --apache -d weye.com.br -d www.weye.com.br
Please also do not forget to add a server alias (Apache) or server name to the existing virtual host that contains the site weye.com.br.
Thank you
Gave a few more tries, tried the suggested command
revoked and deleted the old certificates, cleared cache, restarded apache and the error message is now mentioning a valid certificate but still shows the not secure message
There are some red messages as well on https://www.ssllabs.com/ssltest/analyze.html?d=www.weye.com.br, but I don’t know if they are normal for certbot or not.
On firefox it opens without problem.
I'm going to dive into this, because I think my server alias is already set up but I'm not sure about it.
Now your certificate is correct.
You have a Grade A, that's good. Java 6u45 isn't something you have to support, so the red warning is no problem.
The results of ssllabs are independent from the use of certbot.
so what is this error about?
There may be folks here who read Portuguese, but I'm not one of them. However, the previous screen shot you posted appears to say that the certificate is valid. It also appears to have a link for more information, which might help answer why your copy of Chrome is giving you problems. Whynopadlock.com indicates everything is fine too:
https://www.whynopadlock.com/results/1dff388a-3d9d-4ab1-859b-ae0b4496e72e
Its a red message saying “Not secure”
I don't see that error. And "certificato (valido)" sounds good :wink:
I see:
br
Yes, I could figure out that much. The screen shot you posted earlier (23 minutes ago) had a bit more text which I couldn't figure out, but which probably explains in a bit more detail what the problem is. That's the one that also says your certificate is valid.
