Installed SSL is invalid
My domain is: www.eddy4ai.com
It produced this output: Congratulations! You have successfully enabled https://www.eddy4ai.com
My web server is (include version): Apache/2.4.6
The operating system my web server runs on is (include version): CentOS Linux release 7.9.2009 (Core)
My hosting provider, if applicable, is: Alibaba Cloud
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.11.0
Hi @tonyhuang
there are two critical errors, see your check, ~~4 hours old - https://check-your-website.server-daten.de/?q=eddy4ai.com#url-checks
First, you have created the wrong certificate:
CN=www.eddy4ai.com
	25.01.2021
	25.04.2021
expires in 89 days	www.eddy4ai.com - 1 entry
The non-www domain name is missing, so your non-www isn't secure.
Check your config with apachectl -S, add a ServerAlias, then create a new certificate with both domain names.
Second:
• http://eddy4ai.com/ 47.252.31.177 301 http://47.252.31.177/ 0.407 D
• http://www.eddy4ai.com/ 47.252.31.177 301 https://www.eddy4ai.com/
Html is minified: 100,00 % 0.204 A
• http://47.252.31.177/ 200 Html is minified: 132,50 % 0.450 H
• https://eddy4ai.com/ 47.252.31.177 301 https://47.252.31.177/ 4.843 N
Certificate error: RemoteCertificateNameMismatch
• https://www.eddy4ai.com/ 47.252.31.177 301 https://47.252.31.177/ 4.607 B
Redirects to ip addresses are always wrong. You don't have a certificate with an ip address. Redirect to your domain name.
Got it. Thanks a lot JuergenAuer! I haven't built a website since 1998 where I was using Frontpage. I'm refreshing my skills now. Your instruction is very informative and helpful!!!
Wow!
Definitely time for an update :wink:
Says the guy holding their "Latest Version":
