For some reason, you’ve got a self signed certificate installed. Output from openssl s_client -connect varmlandsk.ordbok.gratis:443 -servername varmlandsk.ordbok.gratis:
I think the problem could be that I am using the apache module: mod_vhost_alias, with a single sites-available/vhosts.conf file for all the thousand domains.
The vhosts.conf file only contains
UseCanonicalName Off
VirtualDocumentRoot /var/www/http/%0/www
I could neither find any information in the documentation nor in the community about what configuration file to use, and if letsencrypt at all works with mod_vhost_alias
How did you configure the current (self signed) certificate for static-237-143.junet.se? In default-ssl.conf perhaps? Because somehow one of those hostnames serves the Let’s Encrypt intermediate certificate… So somewhere you’ve made a configuration change I think…
As I can see, there isn’t an option for SSL with mod_vhost_alias, but what’s suggested is putting the mod_vhost_alias dynamic stuff in a separate <VirtualHost *:80> piece and the SSL-stuff in its own <VirtualHost *:443>, without dynamic virtualhosts… You say you’ve got thousand domains… I hope you don’t have 1000 HTTPS domains, because I haven’t found a way to load the SSL stuff dynamically
From the beginning I only had my vhosts.conf file… but I could not complete the certificate installation process with ./letsencrypt-auto
I recieve an error:
ssl_error_rx_record_too_long
So i tried to install an default-ssl.conf file… and I assume that the self signed certificate simply came from this template. So it was a stupid error.
Now I deleted the content in the default-ssl.conf file… and I am back with the original error:
I dont have any intentions to make all thousand domains secure. But I am developing an online dictionary with voice recording features, and I need to make at least one of the domains secure, in order to use the new getUserMedia javascript functions for Chrome and Opera. This only works over a secure connections. And I still need to keep mod_vhost_alias enabled for obvious reasons, because I connot use manually configured conf-files for thousands of server names.
What exactly gives this ssl_error_rx_record_too_long error? Did you do something to cause this? Or did you just ran letsencrypt-auto, after which the error occured?
Obviously to cause a SSL error message, you’ve got to have some sort of SSL configuration directives set up somewhere… So where does the error come from if you’ve deleted the default-ssl.conf file?
From what I can find, that ssl_error_rx_record_too_long error is a Firefox error? Not a server error message? Would be helpful to specify that
Well, at the moment you’ve got Apache listening on port 443 without SSL:
osiris@desktop ~ $ openssl s_client -connect varmlandsk.ordbok.gratis:443 -servername varmlandsk.ordbok.gratis
CONNECTED(00000003)
140434776250000:error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol:s23_clnt.c:795:
osiris@desktop ~ $ telnet varmlandsk.ordbok.gratis 443
Trying 146.66.237.143...
Connected to varmlandsk.ordbok.gratis.
Escape character is '^]'.
GET / HTTP/1.1
Host: varmlandsk.ordbok.gratis
HTTP/1.1 200 OK
Obviously, Apache should do SSL on port 443, not just non-SSL HTTP… So:
Now you should add an <Virtualhost *:443> for your three HTTPS VirtualHosts. (Three separate instances of <VirtualHost *:443>, because you’ve got three webroots…) You could use the Mozilla SSL Configuration Generator for this. Just add the usual ServerName and DocumentRoot stuff also in there, for example, at the point of the first ... part… Please do look at the links after the “See also:” part. Lots of information in the Mozilla TLS Guidelines.
Great… I feel this problem could be about to be solved.
I generated configuration file text, but I simply cannot find any information on the letsencrypt website about which paths that I should use for my certificates and the key… in the configuration file. This is what I have made so far:
You should look in the /etc/letsencrypt/live directory. You'll probably find one directory: the first domain you specified with -d on the initial command line invocation of the LE client. That's probably ordbok.gratis when I look at your first post in this thread.
Did you correctly set all the version numbers of the software in the generator? I.e., you've got an Apache version below 2.4.8? If that is indeed the case, you should point SSLCertificateFile to the cert.pem you've found in /etc/letsencrypt/live/yoursubdomain/, SSLCertificateChainFile to chain.pem and SSLCertificateKeyFile to privkey.pem. If you won't be doing any client certificate authentication (which probably is the case), you can delete SSLCACertificateFile.
As you've generated one certificate for all three domains, you can just repeat the same SSLCertificate... directives (i.e.: with the same file names), because this one certificate is valid for all domains.
By the way: I see you didn't adopted the SSLProtocol parts of the Mozilla SSL Generator? And also not the OCSP part (if your Apache is recent enough that is, otherwise the generator won't show it anyway..) Is this on purpose? It's probably wise to enter your used version number of Apache and OpenSSL, choose one of the "Modern", "Intermediate" or "Old" compatibility settings (you can see the supported OS and browser versions change if you change the compatibility setting on the fly) and take over the SSLProtocol and SSLCipherSuite parts.. SSLHonorCipherOrder on is always a good thing.
I entered the versions of apache2 and openssl, and I entered the generated SSLProtocol part in the conf file. But I dit not want to enter this information here.
Great… it works. Now I can use getUserMedia… and I dont have to learn Flash-programming. So, this can well have saved me a couple of weeks of labour ha ha…
