Certificate for Raspberry Pi / nginx
jstaylor.com
nginx
Raspbian Bullseye
myself
no
Ok, what's your question?
What do I tell the bot? I see no reference to Raspbian or Debian 11m frinm which it is derived
If Certbot is installed, commands are the same on every platform.
The recommend way to install Certbot is via snap.
so I just enter the commands and see if it will support my confifuration that way?
There are instructions for Debian 10, they should be pretty close.
Thanx. I'll try it and see what happens.
