Certificate for Mamp Pro
My domain is: plentipeppa.co.tt
I ran this command: sudo certbot certonly --webroot -w /Applications/MAMP/htdoc
It produced this output: unauthorized, check A/AAAA
My web server is (include version): MAMP PRO
The operating system my web server runs on is (include version): macOs high sierra
Hi @Plentipeppa
please share your log:
/var/log/letsencrypt/letsencrypt.log
And create a file (file name 1234) in
/Applications/MAMP/htdoc/.well-known/acme-challenge
then try to load this file via
http://plentipeppa.co.tt/.well-known/acme-challenge/1234
to check if your webroot parameter is correct.
Solved, on the MAMP PRO server
