I ran this command: certbot certonly --standalone -d www.thomas.miglinci.name -d thomas.miglinci.name
Checking afterwards using certbot certificates showed:
Found the following certs:
Certificate Name: www.thomas.miglinci.name
Domains: www.thomas.miglinci.name thomas.miglinci.name
Expiry Date: 2025-02-26 12:30:10+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/www.thomas.miglinci.name/fullchain.pem
Private Key Path: /etc/letsencrypt/live/www.thomas.miglinci.name/privkey.pem
Nevertheless, if opening a website with https://thomas.miglinci.name in Chrome brings up an invalide certificate warning.
I do have a forwarding from thomas.miglinci.name to www.thomas.miglinci.name via apache on my server, therefore I did not recognize this and to be honest, I did not care about this at all.
But with Bluesky you can use your domain as your handle, but thomas.miglinci.name was rejected as not being covered by the certificate?!
That is unusual to use --standalone when you have a running Apache server. The --standalone option requires exclusive use of port 80 so requires Apache to be stopped before-hand. Usually a --webroot or even certonly --apache is used instead.
That said, you have gotten certs with different combinations of your names. Some with just your www subdomain and some with that and your apex name. See pic below from https://crt.sh
Your Apache server is using one from Oct19 with only your www subdomain in it. Using that cert and your apex domain will fail with invalid cert. Which is what you see.
Okay, I see.
Seems like I bricked it somehow. I did had some parallel entries in the live-directory with -0001 ending which were not used by my server. So I removed them - or lets say, I invalidated them by changing the extension to .bup; they are still there but are no longer recognized by certbot....
So is there a chance to revoke certificates just by their crt.sh ID ? Because then I would like to get rid of all but the first one.
I revoked this changes and here a the outputs:
$ certbot certificates
$ apache2ctl -t -D DUMP_VHOSTS
VirtualHost configuration:
*:80 is a NameVirtualHost
default server srv4hai.viehai.at (/etc/apache2/sites-enabled/000-default.conf:3)
port 80 namevhost srv4hai.viehai.at (/etc/apache2/sites-enabled/000-default.conf:3)
port 80 namevhost www.viehai.at (/etc/apache2/sites-enabled/010-viehai.conf:1)
alias viehai.at
port 80 namevhost thomas.miglinci.name (/etc/apache2/sites-enabled/022-thomas.conf:1)
alias www.thomas.miglinci.name
port 80 namevhost margarete.rozum.name (/etc/apache2/sites-enabled/margarete.conf:1)
alias www.margarete.rozum.name
port 80 namevhost cloud.viehai.at (/etc/apache2/sites-enabled/owncloud.conf:1)
port 80 namevhost mail.viehai.at (/etc/apache2/sites-enabled/roundcube.conf:1)
*:443 is a NameVirtualHost
default server margarete.rozum.name (/etc/apache2/sites-enabled/margarete-le-ssl.conf:2)
port 443 namevhost margarete.rozum.name (/etc/apache2/sites-enabled/margarete-le-ssl.conf:2)
port 443 namevhost cloud.viehai.at (/etc/apache2/sites-enabled/owncloud-le-ssl.conf:2)
port 443 namevhost mail.viehai.at (/etc/apache2/sites-enabled/roundcube-le-ssl.conf:2)
port 443 namevhost thomas.miglinci.name (/etc/apache2/sites-enabled/thomas-le-ssl.conf:2)
port 443 namevhost www.viehai.at (/etc/apache2/sites-enabled/viehai-le-ssl.conf:2)
alias viehai.at
Attempting to renew cert (www.thomas.miglinci.name) from /etc/letsencrypt/renewal/www.thomas.miglinci.name.conf produced an unexpected error: Problem binding to port 80: Could not bind to IPv4 or IPv6.. Skipping.
The following certs could not be renewed:
/etc/letsencrypt/live/www.thomas.miglinci.name/fullchain.pem (failure)
but all other hosted domains were okay:
The following certs were successfully renewed:
/etc/letsencrypt/live/cloud.viehai.at/fullchain.pem (success)
/etc/letsencrypt/live/mail.viehai.at/fullchain.pem (success)
/etc/letsencrypt/live/viehai.at/fullchain.pem (success)
/etc/letsencrypt/live/www.margarete.rozum.name/fullchain.pem (success)
This seems like the same problem as earlier. The --standalone option requires exclusive use of port 80. But, you have an Apache server using port 80. Which is all fine and good. But, you should use --apache or --webroot method with Apache - not --standalone.
alias viehai.at
alias viehai.at
default 443-server should be a different one (preferable srv4haI.viehai.at) but that is another story...
After looking into /etc/letsencrypt/renewal/www.thomas.miglinci.name.conf and comparing to another one I found the difference in the # Options used in the renewal processsection. And after fixing that...
