Certificate creation using certbot and route53 fails
Starting yesterday, 03.06.2024 I can no longer issue new certificates using certbot and having my domain hosted on AWS Route53. The domain has DNSSEC configured to "not signing". I am certain this has worked on 31.05.2024
My domain is: i-05b3c67ca68a810b1.sandbox.devl.awhap.hev.cloud
certbot certonly --dns-route53 -d i-05b3c67ca68a810b1.sandbox.devl.awhap.hev.cloud -d *.i-05b3c67ca68a810b1.sandbox.devl.awhap.hev.cloud -n --agree-tos --email hap@helvetia.ch
Found credentials from IAM Role: <redacted, it is the correct IAM Role with correct permissions>
Plugins selected: Authenticator dns-route53, Installer None
Requesting a certificate for i-05b3c67ca68a810b1.sandbox.devl.awhap.hev.cloud and *.i-05b3c67ca68a810b1.sandbox.devl.awhap.hev.cloud
dns-01 challenge for i-05b3c67ca68a810b1.sandbox.devl.awhap.hev.cloud
Challenge failed for domain i-05b3c67ca68a810b1.sandbox.devl.awhap.hev.cloud
Certbot failed to authenticate some domains (authenticator: dns-route53). The Certificate Authority reported these problems:
  Domain: i-05b3c67ca68a810b1.sandbox.devl.awhap.hev.cloud
  Type:   dns
  Detail: DNS problem: looking up TXT for _acme-challenge.i-05b3c67ca68a810b1.sandbox.devl.awhap.hev.cloud: DNSSEC: DNSKEY Missing
  Type:   dns
Hint: The Certificate Authority failed to verify the DNS TXT records created by --dns-route53. Ensure the above domains have their DNS hosted by AWS Route53.
My web server is (include version): traefik
The operating system my web server runs on is (include version): UBI9 (traefik runs inside a docker container, the issue doesn't really reach that point)
My hosting provider, if applicable, is: not applicable
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.10.0
For further details, this is the log file that certbot produced when running the command.
certbot_log.txt (204.0 KB)
Yes, it's not signing, but the domain is still configured at the registrar to be DNSSEC-signed. In order for your domain to work, you need to either sign it with the same key you have configured at the registrar, or have the registrar turn off DNSSEC as well.
In addition, the NS records set at the registrar need to match the NS records served by the authoritative DNS servers.
See the DNSViz report
This really isn't related to certificates; you just need a working domain name before one can get a certificate for it, or really for anyone to use that domain name at all. Once you've fixed DNS so that your domain name works again, then you should be able to get certificates for it.
