Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=example.com), so withholding your domain name here does not increase secrecy and only makes it harder for us to provide help.
My domain is: moden.uno, *.moden.uno
I ran this command: sudo certbot certonly -v --dns-route53 -i nginx -d moden.uno -d *.moden.uno --test-cert --break-my-certs
(Note: I use --break-my-certs only because --test-cert requires it.)
Credentials found in config file: ~/.aws/config
Plugins selected: Authenticator dns-route53, Installer nginx
requested (ref: /etc/letsencrypt/renewal/moden.uno.conf)
It contains these names: moden.uno
You requested these names for the new certificate: moden.uno, *.moden.uno.
certificate?
(E)xpand/(C)ancel: e
Renewing an existing certificate for moden.uno and *.moden.uno
dns-01 challenge for moden.uno
Challenge failed for domain moden.uno
Certbot failed to authenticate some domains (authenticator: dns-route53). The Certificate Authority reported these problems:
Domain: moden.uno
Detail: No TXT record found at _acme-challenge.moden.uno
Domain: moden.uno
Hint: The Certificate Authority failed to verify the DNS TXT records created by --dns-route53. Ensure the above domains have their DNS hosted by AWS Route53.
(Note: The redundant dns-01 challenge for moden.uno only happens when I use --test-cert)
My web server is (include version): nginx/1.22.1
The operating system my web server runs on is (include version): Debian 12
My hosting provider, if applicable, is: Route 53 pointing to a Lightsail instance.
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.9.0
Comments: Hello! I have followed and double checked the instructions on the certbot website, here. I have also checked that the certbot process has a proper AWS IAM user, permissions, and credentials, as a different error occurs if any are wrong. I have also verified that the TXT record/s are created on Route 53; I am not sure how or why the above error types are "unauthorized."
I can check Route 53 and see that the TXT record is added when certbot runs (and removed when certbot finishes), but external investigation has never shown the record. The certbot process errors-out after about 30 seconds, but I have never had a record propagate on Route 53 within that time. I have a feeling that the record is not being given time to propagate, but the --dns-route53-propagation-seconds argument has been deprecated.
I appreciate any feedback the community may have and am more than happy to answer any questions.
