I have received a certificate chain from letsencrypt. I’m using windows server, Tomcat 9 with keystore. The certificate chain fails with the message.
This site can’t provide a secure connection
info.finwoks.com sent an invalid response.
Try running Windows Network Diagnostics.
ERR_SSL_PROTOCOL_ERROR
Diagnostics does not tell me anything.
If I double click on the certificate chain I get an output that show the certificate path as
DST Root CA X3
Let’s Encrypt Authority X1
info.finwoks.com
The last being my domain name
I can click on first two and then on View Certificate and see those certificates… However the last, my domain certificate the View Certificate is grayed out, but the Certificate status: says This certificate is OK.
I then ran OpenSSL openssl x509 -in domain-chain.crt -noout -text and got -
Certificate:
Data:
Version: 3 (0x2)
Serial Number:
03:e5:f1:25:dd:45:fe:cb:bb:ed:b7:e2:2d:6c:a7:39:6a:a4
Signature Algorithm: sha256WithRSAEncryption
Issuer: C=US, O=Let’s Encrypt, CN=Let’s Encrypt Authority X3
Validity
Not Before: Oct 23 19:43:04 2017 GMT
Not After : Jan 21 19:43:04 2018 GMT
Subject: CN=info.finwoks.com
Subject Public Key Info:
Public Key Algorithm: rsaEncryption
RSA Public Key: (2048 bit)
Modulus (2048 bit):
00:b3:c1:fe:ad:12:aa:19:48:e7:99:6b:1a:e0:ac:
9f:58:f2:96:60:30:1c:da:e9:f7:28:e7:dd:03:3c:
44:d6:56:c8:12:31:b8:1d:13:62:6b:64:64:05:56:
d3:c3:1d:c9:d8:ab:43:78:52:7e:26:09:4b:34:45:
1c:31:e5:c0:f6:aa:85:2b:32:b7:4f:c1:0d:58:b0:
13:96:25:99:fa:c8:8b:74:bc:11:cf:a8:11:47:f5:
f2:78:2c:1a:76:d0:a1:e3:79:ce:3e:6b:43:1d:33:
c9:22:5b:95:28:d8:4a:0e:c8:27:84:5f:76:97:5c:
ce:be:c7:2b:8f:3c:7b:da:84:6c:df:8a:cc:70:54:
a0:78:f4:73:af:75:9f:20:ba:18:35:3c:1e:e1:43:
5e:74:e8:cb:1a:20:99:67:ff:34:dc:45:46:02:9e:
59:f9:2c:19:8c:db:fd:9e:ed:71:b4:e6:71:12:7b:
b5:22:ed:e4:38:06:ed:97:d6:b0:6d:5d:54:9d:44:
f2:55:43:45:f6:ab:a9:25:aa:7e:d2:df:3b:98:b9:
e6:ae:52:2d:d0:48:0d:59:e4:b9:a1:69:36:bf:13:
3b:70:a4:df:fd:63:0c:0d:38:94:9d:89:51:2b:66:
9f:ba:8b:9c:fd:1b:d5:d4:a2:73:47:d5:4f:71:4f:
4a:77
Exponent: 65537 (0x10001)
X509v3 extensions:
X509v3 Key Usage: critical
Digital Signature, Key Encipherment
X509v3 Extended Key Usage:
TLS Web Server Authentication, TLS Web Client Authentication
X509v3 Basic Constraints: critical
CA:FALSE
X509v3 Subject Key Identifier:
3A:62:01:AD:83:83:3E:E8:E5:23:6B:C2:42:33:76:05:B9:BE:2B:D5
X509v3 Authority Key Identifier:
keyid:A8:4A:6A:63:04:7D:DD:BA:E6:D1:39:B7:A6:45:65:EF:F3:A8:EC:A1
Authority Information Access:
OCSP - URI:http://ocsp.int-x3.letsencrypt.org
CA Issuers - URI:http://cert.int-x3.letsencrypt.org/
X509v3 Subject Alternative Name:
DNS:info.finwoks.com
X509v3 Certificate Policies:
Policy: 2.23.140.1.2.1
Policy: 1.3.6.1.4.1.44947.1.1.1
CPS: http://cps.letsencrypt.org
User Notice:
Explicit Text: This Certificate may only be relied upon by Relying Parties and only in accordance with the Certificate Policy found at https://letsencrypt.org/repository/
3a:c2:6b:e8:a0:54:d3:24:24:49:20:39:1d:85:e8:06:37:68:
e7:f4:66:1c:8f:fb:67:61:c4:70:9f:64:76:02:60:27:07:69:
7b:74:38:ac:9f:cb:03:eb:8c:79:d6:aa:23:03:62:41:7c:bd:
28:d9:e4:27:41:86:66:a6:c7:4c:f6:b8:66:90:d9:6f:a2:26:
b2:3a:4f:c3:bf:e9:f6:05:87:fb:0d:ee:29:72:90:14:07:3f:
cc:42:20:30:a7:94:53:6e:52:be:de:f0:95:90:83:49:c5:7e:
91:11:35:1e:57:7e:25:63:db:bf:99:60:a9:d5:3d:c7:c0:39:
64:c2:25:26:35:65:8a:73:10:2c:ed:ba:2c:b3:41:98:bc:65:
3f:ae:ff:21:37:76:d0:85:87:45:08:df:55:fd:91:58:8f:fe:
04:f8:c5:59:ea:d5:f1:92:4d:0d:38:ff:e7:b2:55:0b:b2:3c:
81:7b:23:df:de:dd:77:89:a7:bf:0b:a3:dc:fd:7f:09:6f:da:
5c:a6:88:3d:c8:ce:f4:d9:21:1a:a4:b7:2b:0a:bc:bc:6f:56:
5c:b9:30:94:fb:ba:67:70:f5:46:6b:3e:89:16:7c:86:51:3d:
b0:28:f5:32:07:4b:09:c6:0f:fb:58:90:2f:cb:b8:30:48:eb:
79:b4:ef:20
My Question Is the domain certificate corrupted or missing? Windows seems to say it is there.
Any clarification would be appreciated.
Don
