Certificate activation issue
My domain is: All Domains
I ran this command: /usr/local/vesta/bin/v-add-letsencrypt-domain user mydomain.com.br www.mydomain.com.br
It produced this output: Let’s Encrypt nonce request status / [Error 15]
The operating system my web server runs on is (include version): Ubuntu 18.04.2 LTS
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): VestaCP
Hello, I’m having trouble activating the certificate, every time I get the following error message: Let’s Encrypt nonce request status, when I check the log it shows me as Error code 15 and it happens to all domains without exception
2019-10-11 11:39:10 v-add-letsencrypt-domain ‘user’ ‘mydomain.com.br’ ‘www.mydomain.com.br’ ‘no’ [Error 15]
Hi @Gabriel
looks like an internal error of your VestaCP. Is there an update? There are some topics (last days) with nonce problems. Check, if you can update your VestaCP.
If I upgrade vesta would we lose the existing settings and domains on the server?
I don't know, never used VestaCP. But normally that should work.
