Bonjour, ![]()
J'ai créé un site internet mais il dysfonctionne car je n'ai pas de certificat SSL d'installé sous OVH. je ne suis pas développer j'utilise DIVI donc si quelqu'un aurait la gentillesse et la patience de m'expliquer simplement comment faire, ce serait formidable.
Merci pour votre attention, Bettina
PS: Mon site: https://classecroute.fr/
Welcome @Bettina I hope you can understand or translate English.
Your website has an SSL certificate and has a good score from SSL Labs. Can you describe more why you think you need to do more? SSL Labs test result: SSL Server Test: classecroute.fr (Powered by Qualys SSL Labs)
I see some "Mixed Content" problems on your site but these are not related to your certificate. You are using HTTP links on your site when you should use HTTPS: Test Results: classecroute.fr - Why No Padlock?
Hello MikeMcQ, and thank you for your response, how come I use HTTP links on your site even though the site is registered in HTTPS? Bettina
Would you explain more about this:
Because your website has a certificate. But your site has some HTTP links for some WordPress fonts. This is setup in your WordPress configuration. You should use HTTPS links.
When I visit your site the certificate works. But, there is this warning because of the HTTP links. This is not related to Let's Encrypt. Your hosting service (OVH) or the DIVI support forum can help with this.
Thanks YOU verry much !
Hello MickMCQ,
Je viens de faire le nécessaire auprès de DIVI, pouvez-vous m'indiquer si j'ai réussi à réparer?
Bien à vous. Bettina
I see the same Mixed Content problem as before. You can test yourself with this site:
Merci pour ce précieux retour, je vais me renseigner.
A présent le test semble ok mais j'ai toujours les mêmes messages d'erreur sur le site
What is that error?
You should ask the Really Simple Security team about those items. I don't know exactly what they are complaining about.
Your Let's Encrypt certificate configuration looks good to me. Also this testing site
https://www.ssllabs.com/ssltest/analyze.html?d=classecroute.fr&s=145.239.37.162&hideResults=on&ignoreMismatch=on
Pouvez-vous m'indiquer le lien de l'équipe de test s'il vous plaît?
Sorry, no. I do not work for them. There should be a contact on that website you showed.
Or, a contact might have been given to you when you signed up for that service.
Thank you for your advice I will contact them, have a good day.
