Hi, I just used certbot certonly --webroot to obtain certificates for several domains. The command ran perfectly with no errors. I wanted to check that the renewal process would work though so I ran certbot renew --dry-run and it failed for almost all the domains. Any common reason why this might happen? I’m using nginx on Debian Stretch. Thanks
Edit: Also, since it seems like there’s no nginx plugin on Stretch to automatically change my configuration, which changes need to be made in /etc/nginx/sites-enabled/…? Thanks again
