Certbot TLS-SNI-01 issue
Sorry, I just received the email about certbot / letsencrypt and the TLS-SNI-01 security issue. I followed the other topics (which are now closed) but have an issue where our firewall and apache server do not allow port 80 (http) so the webroot apache method using http-01 is failing because I cannot get it to use https to connect to our domain. Has there been a work around for this yet or something I overlooked?
My domain is: twrnoc.com
certbot --authenticator webroot --installer apache --webroot-path /var/www/html/portal -d twrnoc.com
Failed authorization procedure. twrnoc.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://twrnoc.com/.well-known/acme-challenge/l6ZlTGUKpd3BrrPUXiFTyP8l02Y1JDZYFAsnx8hlQDg: Timeout during connect (likely firewall problem)
Apache
FC23
Yes
Hi @jamesarm97
this is a public website. Why is port 80 closed? Every website should answer with port 80 and port 443.
But if you can't open port 80, you have to use dns-01 validation. Or the new tls-alpn-validation.
But dns-01 validation requires a dns txt entry, every 60 - 85 days new. So without an API it's terrible.
This may help you (the PPA obviously won’t work on Fedora and I don’t know if there’s an equivalent for 23, but the other options may work).
