Certbot stuck at 0.22.2. How to get to .28?
My domain is: .com
I ran these command: sudo apt-get update sudo apt-get install software-properties-common
sudo add-apt-repository universe sudo add-apt-repository ppa:certbot/certbot
sudo apt-get update sudo apt-get install certbot python-certbot-apache
The first 5 commands succeed as expected.
The last command does not upgrade certbot and produces this output:
Reading package lists… Done
Building dependency tree
Reading state information… Done
python-certbot-apache is already the newest version (0.25.0-2+ubuntu17.10.1+certbot+1).
certbot is already the newest version (0.22.2-1+ubuntu17.10.1+certbot+1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
My web server is Apache 2.4.27
The operating system my web server runs on is Ubuntu 17.1
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.22.2
When I do the dry run everything succeeds.
$ sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/.com.conf
http-01 challenge for .com
http-01 challenge for www..com
Waiting for verification…
new certificate deployed with reload of apache server; fullchain is
/etc/letsencrypt/live/.com/fullchain.pem
/etc/letsencrypt/live/.com/fullchain.pem (success)
Ubuntu 17.10 is EOL. The Certbot PPA no longer contains new packages for it. :sweat:
You should upgrade to Ubuntu 18.04.
Thanks. I was afraid of that. That’ll be the last time I run anything important on a non-LTS version…
