Today I learned about the whole tls-sn-01 problem. Thankfully cert renewal still works (though that’s unrelated to my problem at hand). I’m trying to get some new certs in standalone mode, but it’s failing with a timeout:
www.skillvoyage.net, mathgoddess.skillvoyage.net, melissa.skillvoyage.net
certbot --authenticator standalone --installer nginx -d www.skillvoyage.net -d mathgoddess.skillvoyage.net -d melissa.skillvoyage.net
I’ve also tried with the individual domains. Still no dice.
# certbot --authenticator standalone --installer nginx -d www.skillvoyage.net -d mathgoddess.skillvoyage.net -d melissa.skillvoyage.net
Plugins selected: Authenticator standalone, Installer nginx
requested (ref: /etc/letsencrypt/renewal/www.skillvoyage.net.conf)
It contains these names: www.skillvoyage.net
You requested these names for the new certificate: www.skillvoyage.net,
mathgoddess.skillvoyage.net, melissa.skillvoyage.net.
certificate?
(E)xpand/(C)ancel: e
tls-sni-01 challenge for www.skillvoyage.net
http-01 challenge for mathgoddess.skillvoyage.net
http-01 challenge for melissa.skillvoyage.net
Failed authorization procedure. melissa.skillvoyage.net (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://melissa.skillvoyage.net/.well-known/acme-challenge/SmUURvBf4ALu8KjoGbn9WxfKJxvWsbr1TqdaW3uziAs: Timeout, mathgoddess.skillvoyage.net (http-01): urn:acme:er
ror:connection :: The server could not connect to the client to verify the domain :: Fetching http://mathgoddess.skillvoyage.net/.well-known/acme-challenge/96h0e9JuxxczFK1M8JGmkQUuSacSIM5dnN7ZIdVxKbg: Timeout
Domain: melissa.skillvoyage.net
Type: connection
Detail: Fetching
Timeout
Domain: mathgoddess.skillvoyage.net
Type: connection
Detail: Fetching
Timeout
# certbot --version
certbot 0.21.1
CentOS Linux release 7.4.1708 (Core)
AlphaRacks
Yes
No
At the moment I don’t have anything listening on 80 or 443 because I’m trying to run certbot in standalone mode, but I did verify that I could stand a simple server (i.e. python2.7 -m SimpleHTTPServer 80) and connect to it from the outside world.
Any clue what’s going on here?
