Certbot stand-alone return error Timeout during connect (likely firewall problem)
Please help. I cannot generate the certificate for my domain using standalone mode. I've done a test on Letdebug.net and it said that the connection is OK, but when i run certbot still get the Timeout error.
My domain is: chat.campdi.vn
certbot certonly --standalone --preferred-challenges http --http-01-port 80 -d chat.campdi.vn
Requesting a certificate for chat.campdi.vn
http-01 challenge for chat.campdi.vn
Challenge failed for domain chat.campdi.vn
    Domain: chat.campdi.vn
    Type: connection
    Detail: During secondary validation: 1.53.141.231: Fetching
    http://chat.campdi.vn/.well-known/acme-challenge/PxiFDSK54lNo7h7ILzF0yK7mgxQxjFlIP4riEoi_1Mc:
My web server is (include version): haproxy
The operating system my web server runs on is (include version): centos 7
The version of my client is 1.11.0
Please see:
I'm getting something different:
ANotWorking
ERROR
chat.campdi.vn has an A (IPv4) record (1.53.141.231) but a request to this address over port 80 did not succeed. Your web server must have at least one working IPv4 or IPv6 address.
Hi, can you help to check for the domain chatbotchang.fpt.vn. I've setup a new domain to confirm if there's any problems. Letsdebug work fine for this domain
Let's Debug
](https://letsdebug.net/)
Test result for chatbotchang.fpt.vn using http-01
All OK!
OK
No issues were found with chatbotchang.fpt.vn. If you are having problems with creating an SSL certificate, please visit the Let's Encrypt Community forums and post a question there.
The --standalone method is difficult to debug because you need to keep Certbot running to test connection from the public internet.
A way to test this easier is to use these command options
certbot certonly --standalone --dry-run --debug-challenges -v -d (domain) --http-01-port 80
This command will show you the challenge URL to try from the public internet and the proper response. After showing you this it will say "Press Enter to Continue". DO NOT PRESS ENTER.
Leave it paused like that and use a different device to test connection. You can use a mobile phone with wifi disabled so use your carrier's network.
You do not have to use the full URL. Just try http://(yourdomain)
If the connection works this shorter URL should see a response like below. The error in your first post said "Secondary validation" which is a problem just from certain locations. Osiris already linked to an article about that. Make sure your domain can be reached from anywhere.
ACME client standalone challenge solver
