Certbot SSL installed but not working
Hello There,
I have just installed the certbot ssl on our linode VPS server, i logged into our server via ssh & followed the instructions on your website on how to configure the ssl certificate and i was able to do it successfully as you can see in the screenshot below
i’ve also tested my configuration at ssllabs website & the test came back positive. my issue is that wen i load the url https://bestmobileltd.com. i don’t see the padlock icon on the top-left that one usually see to indicate that the site is secure. you can see it in the screenshot below.
if you could pls assist me with this issue, i will very much appreciate it
Thank You
You have a redirect on your website that is sending people back to the insecure version of the site.
$ curl -i https://www.bestmobileltd.com/
HTTP/1.1 302 Found
Date: Fri, 12 Jan 2018 11:35:18 GMT
Server: Apache/2.4.7 (Ubuntu)
X-Powered-By: PHP/5.5.9-1ubuntu4.20
Check your .htaccess file for any rewrite rules that may be doing this.
It looks like some PHP application is sending the redirect, not the Apache configuration itself.
i tried modifying the .htaccess file to redirect to https://www.bestmobileltd.com but it didn’t work, nothing happened. here’s the screenshot of my .htaccess file with the edits that i made. have a look and see if there’s anything else that i can do to make it work. also keep in mind this file is located in the root of the website which is a magento website
uncomment these lines for CGI mode
make sure to specify the correct cgi php binary file name
it might be /cgi-bin/php-cgi
Action php5-cgi /cgi-bin/php5-cgi
AddHandler php5-cgi .php
GoDaddy specific options
Options -MultiViews
you might also need to add this line to php.ini
cgi.fix_pathinfo = 1
if it still doesn’t work, rename php.ini to php5.ini
this line is specific for 1and1 hosting
#AddType x-mapp-php5 .php
#AddHandler x-mapp-php5 .php
default index file
DirectoryIndex index.php
adjust memory limit
php_value memory_limit 64M
php_value memory_limit 256M
php_value max_execution_time 18000
disable magic quotes for php request vars
php_flag magic_quotes_gpc off
disable automatic session start
before autoload was initialized
php_flag session.auto_start off
enable resulting html compression
#php_flag zlib.output_compression on
disable user agent verification to not break multiple image upload
php_flag suhosin.session.cryptua off
turn off compatibility with PHP4 when dealing with objects
php_flag zend.ze1_compatibility_mode Off
########################################### # disable POST processing to not break multiple image upload
SecFilterEngine Off
SecFilterScanPOST Off
enable apache served files compression
http://developer.yahoo.com/performance/rules.html#gzip
Insert filter on all content
###SetOutputFilter DEFLATE
Insert filter on selected content types only
#AddOutputFilterByType DEFLATE text/html text/plain text/xml text/css text/javascript
Netscape 4.x has some problems…
#BrowserMatch ^Mozilla/4 gzip-only-text/html
Netscape 4.06-4.08 have some more problems
#BrowserMatch ^Mozilla/4.0[678] no-gzip
MSIE masquerades as Netscape, but it is fine
#BrowserMatch \bMSIE !no-gzip !gzip-only-text/html
Don’t compress images
#SetEnvIfNoCase Request_URI .(?:gif|jpe?g|png)$ no-gzip dont-vary
Make sure proxies don’t deliver the wrong content
#Header append Vary User-Agent env=!dont-vary
make HTTPS env vars available for CGI mode
SSLOptions StdEnvVars
enable rewrites
RewriteCond %{HTTP_HOST} ^bestmobileltd.com [NC]
RewriteCond %{SERVER_PORT} 80
RewriteRule ^(.*)$ https://www.bestmobileltd.com/$1 [R,L]
you can put here your magento root folder
path relative to web root
#RewriteBase /magento/
uncomment next line to enable light API calls processing
RewriteRule ^api/([a-z][0-9a-z_]+)/?$ api.php?type=$1 [QSA,L]
rewrite API2 calls to api.php (by now it is REST only)
RewriteRule ^api/rest api.php?type=rest [QSA,L]
workaround for HTTP authorization
in CGI environment
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
TRACE and TRACK HTTP methods disabled to prevent XSS attacks
RewriteCond %{REQUEST_METHOD} ^TRAC[EK]
RewriteRule .* - [L,R=405]
redirect for mobile user agents
#RewriteCond %{REQUEST_URI} !^/mobiledirectoryhere/.$
#RewriteCond %{HTTP_USER_AGENT} “android|blackberry|ipad|iphone|ipod|iemobile|opera mobile|palmos|webos|googlebot-mobile” [NC]
#RewriteRule ^(.
)$ /mobiledirectoryhere/ [L,R=302]
always send 404 on missing files in these folders
RewriteCond %{REQUEST_URI} !^/(media|skin|js)/
never rewrite for existing files, directories and links
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteCond %{REQUEST_FILENAME} !-l
rewrite everything else to index.php
RewriteRule .* index.php [L]
Prevent character encoding issues from server overrides
If you still have problems, use the second line instead
AddDefaultCharset Off
#AddDefaultCharset UTF-8
Add default Expires header
http://developer.yahoo.com/performance/rules.html#expires
ExpiresDefault “access plus 1 year”
By default allow all access
Order allow,deny
Allow from all
Deny access to release notes to prevent disclosure of the installed Magento version
order allow,deny deny from all
If running in cluster environment, uncomment this
http://developer.yahoo.com/performance/rules.html#etags
#FileETag none
Deny access to cron.php
uncomment next lines to enable cron access with base HTTP authorization
http://httpd.apache.org/docs/2.2/howto/auth.html
Warning: .htpasswd file should be placed somewhere not accessible from the web.
This is so that folks cannot download the password file.
For example, if your documents are served out of /usr/local/apache/htdocs
you might want to put the password file(s) in /usr/local/apache/.
#AuthName "Cron auth"
#AuthUserFile ../.htpasswd
#AuthType basic
#Require valid-user
Order allow,deny
Deny from all
Based on that it looks like you are using Magento, perhaps it is a Magento-specific setting. The following page lists a number of settings you may need to look at:
ok, so i’ve click the link & gone through the steps in the tutorial & its kinda working, the backend of the magento website is working fine, its showing me the secure icon at the top left of the browser but when i browse to the frontend of the site the secure icon shows up for a microsecond then dissapears & then it goes back to say the site is unsecure, not sure if this is a redirect issue or what, let show what my .htaccess file looks like. pls have a look and let me know what i can do to let the secure icon show permanently on the frontend of the site. when i browse to www.bestmobileltd.com it redirects to https://www.bestmobileltd.com but it jus doesn’t give me the secure icon at the top left of the browser window.
## uncomment these lines for CGI mode
## make sure to specify the correct cgi php binary file name
## it might be /cgi-bin/php-cgi
#    Action php5-cgi /cgi-bin/php5-cgi
#    AddHandler php5-cgi .php
## GoDaddy specific options
#   Options -MultiViews
## you might also need to add this line to php.ini
##     cgi.fix_pathinfo = 1
## if it still doesn't work, rename php.ini to php5.ini
## this line is specific for 1and1 hosting
## default index file
<IfModule mod_php5.c>
## adjust memory limit
#    php_value memory_limit 64M
## disable magic quotes for php request vars
## disable automatic session start
## before autoload was initialized
## enable resulting html compression
# disable user agent verification to not break multiple image upload
# turn off compatibility with PHP4 when dealing with objects
</IfModule>
<IfModule mod_security.c>
    SecFilterEngine Off
</IfModule>
<IfModule mod_deflate.c>
## enable apache served files compression
## http://developer.yahoo.com/performance/rules.html#gzip
    # Insert filter on all content
    # Insert filter on selected content types only
    # Netscape 4.x has some problems...
    # Netscape 4.06-4.08 have some more problems
    #BrowserMatch ^Mozilla/4\.0[678] no-gzip
    # MSIE masquerades as Netscape, but it is fine
    # Don't compress images
    #SetEnvIfNoCase Request_URI \.(?:gif|jpe?g|png)$ no-gzip dont-vary
    # Make sure proxies don't deliver the wrong content
</IfModule>
<IfModule mod_ssl.c>
## make HTTPS env vars available for CGI mode
</IfModule>
<IfModule mod_rewrite.c>
## enable rewrites
    Options +FollowSymLinks
    RewriteEngine on
## you can put here your magento root folder
## path relative to web root
## uncomment next line to enable light API calls processing
#    RewriteRule ^api/([a-z][0-9a-z_]+)/?$ api.php?type=$1 [QSA,L]
## rewrite API2 calls to api.php (by now it is REST only)
## workaround for HTTP authorization
## in CGI environment
## TRACE and TRACK HTTP methods disabled to prevent XSS attacks
## redirect for mobile user agents
    #RewriteCond %{REQUEST_URI} !^/mobiledirectoryhere/.*$
    #RewriteCond %{HTTP_USER_AGENT} "android|blackberry|ipad|iphone|ipod|iemobile|opera mobile|palmos|webos|googlebot-mobile" [NC]
    #RewriteRule ^(.*)$ /mobiledirectoryhere/ [L,R=302]
## always send 404 on missing files in these folders
## never rewrite for existing files, directories and links
## rewrite everything else to index.php
</IfModule>
## Prevent character encoding issues from server overrides
## If you still have problems, use the second line instead
<IfModule mod_expires.c>
## Add default Expires header
## http://developer.yahoo.com/performance/rules.html#expires
    ExpiresDefault "access plus 1 year"
</IfModule>
## By default allow all access
    Order allow,deny
    Allow from all
## Deny access to release notes to prevent disclosure of the installed Magento version
    <Files RELEASE_NOTES.txt>
        order allow,deny
        deny from all
    </Files>
## If running in cluster environment, uncomment this
## http://developer.yahoo.com/performance/rules.html#etags
    #FileETag none
## Deny access to cron.php
    <Files cron.php>
## uncomment next lines to enable cron access with base HTTP authorization
## http://httpd.apache.org/docs/2.2/howto/auth.html
## Warning: .htpasswd file should be placed somewhere not accessible from the web.
## This is so that folks cannot download the password file.
## For example, if your documents are served out of /usr/local/apache/htdocs
## you might want to put the password file(s) in /usr/local/apache/.
        #AuthType basic
        #Require valid-user
        Order allow,deny
        Deny from all
    </Files>
The http version of your website is hardcoded into a few images in your frontend skin and some Magento CMS pages.
whynopadlock.com will list all the links that are causing your padlock to disappear. You must fix all these to use https or relative URLs.
I changed the hardcoded images to use https but it still didn’t working, then i realised the were some other hardcoded images in the themes css files so i modified them & the ssl now works & i get the padlock sign show.
but this now presents me with a new problem, the magento has become very slow since ssl was enabled on the site. if you coud pls suggest something that i can do to make the site go faster i would very much appreciate it
Thanks
I’ve been encountering the same issue with my site. Regardless of installing the SSL properly (using Dreamhost installer) it keeps on showing “Your connection is not private”. Even my nameserver is properly configured to of Dreamhost’s but still it is showing. How do I fix it??
Update: Later I figured out it was just domain propagation which was taking time. After 24 hours everything is normal again :slight_smile:
Garry Joshi
https://showbox.onl/ https://getmobdro.com/ https://dltutuapp.com/
