Certbot site not working
my problem is with the certbott.eff.org after i selected the system i’m using (Debian 9), the site doesn’t do anything. no downloads, no additional buttons showed up, no nothing.
isn’t it supposed to provide a link or do something? how to install the cert then?
Do you have JavaScript enabled? Have you tried in another browser? Could you look in the browser’s Developer Tools Console?
Did you select both the web server (Software: Apache/nginx/etc) as well as System (Debian etc) ?
yes i have JS enabled in both IE and Firefox that i’ve checked.
oh, i thought you only need to select “System” and that the “Software” part have been pre-selected.
both butttons should be empty to signify it needs to be selected. thank you!
