Certbot running on EC2 instance failing on some domains
Hi Everyone,
As the incoming dev for my company, I've inherited the AWS managment of our sites, set up buy previous developers, we are using Certbot - which seems to be able to renew some domains on the EC2 instance, but not others. I'm wondering if I can get some assistance with the below issue.
eastern-escape.co.uk
sudo certbot renew --dry-run or sudo certbot renew
   Domain: staging.eastern-escape.co.uk
   Type:   connection
   Detail: 3.10.33.189: Fetching
   http://staging.eastern-escape.co.uk/.well-known/acme-challenge/iVwyDaWwbY9JT4_yAlzUjs0gmA_FFKGdHYr-uLcctZs:
   Connection refused
  /etc/letsencrypt/live/staging.burlington-place.co.uk/fullchain.pem (failure)
  /etc/letsencrypt/live/staging.eastern-escape.co.uk/fullchain.pem (failure)
Server version: Apache/2.4.57 (Ubuntu)
Server built: 2023-04-08T12:55:31
Distributor ID: Ubuntu
Description: Ubuntu 20.04.6 LTS
Release: 20.04
Codename: focal
Amazon AWS EC2
Yes (With sudo)
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.40.0
I cannot reproduce the "Connection Refused" from my own AWS test server or from the Let's Debug test site
My guess is you have some sort of firewall blocking the IP address(es) of the Let's Encrypt validation servers.
I see a problem with your Apache server's redirects though. The HTTP Challenge request is being redirected to HTTPS and your home page. Instead, your server needs to reply with the challenge token placed by Certbot.
#Sample HTTP Challenge redirected to index.php
curl -ILk http://staging.eastern-escape.co.uk/.well-known/acme-challenge/Test404 -A "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
HTTP/1.1 302 Found
Server: Apache/2.4.57 (Ubuntu)
Location: https://staging.eastern-escape.co.uk/index.php
# Returns index.php value rather than error 404 (for this test)
# (the -k above is needed to ignore the expired cert for this domain)
HTTP/1.1 200 OK
Date: Thu, 30 Nov 2023 14:35:58 GMT
Hi Mike.
Thanks for getting in touch - I can see the redirection happening, and that could be the rout cause of the issue.
Could you provide some assistance regarding the Apache config as I think I culd be setup slightly wrong?
TIA
Chris.
It is one problem. But, do you still get "Connection Refused" on repeated attempts? And, do you see that Refused with both --dry-run and without? Because this is the first problem to solve.
As for Apache, good place to start is showing us this output
sudo apache2ctl -t -D DUMP_VHOSTS
As an aside, Certbot 0.40 from the apt install of that Ubuntu is very old. The recommended install is using the snap version. Follow the instructions below carefully. There have been numerous improvements to certbot since then. Although, none would resolve a "connection refused"
Hi Mike,
We do indeed get connection refused on eastern for both renew and renew --dry-run
Please see below for the output of $sudo certbt renew
$ sudo certbot renew
Processing /etc/letsencrypt/renewal/staging.burlington-place.co.uk.conf
Running pre-hook command: service apache2 stop
http-01 challenge for staging.maynard-meadows.co.uk
Challenge failed for domain staging.maynard-meadows.co.uk
Attempting to renew cert (staging.burlington-place.co.uk) from /etc/letsencrypt/renewal/staging.burlington-place.co.uk.conf produced an unexpected error: Some challenges have failed.. Skipping.
Processing /etc/letsencrypt/renewal/staging.eastern-escape.co.uk.conf
http-01 challenge for staging.eastern-escape.co.uk
Challenge failed for domain staging.eastern-escape.co.uk
Attempting to renew cert (staging.eastern-escape.co.uk) from /etc/letsencrypt/renewal/staging.eastern-escape.co.uk.conf produced an unexpected error: Some challenges have failed.. Skipping.
Running post-hook command: service apache2 start
2 renew failure(s), 0 parse failure(s)
   Type:   connection
   http://staging.eastern-escape.co.uk/.well-known/acme-challenge/XXvl3jRHBKO12dJtj5FW7fZtFRf7qw4MwuGLKPBNou4:
   Connection refused
   Domain: staging.maynard-meadows.co.uk
   Type:   dns
   Detail: DNS problem: NXDOMAIN looking up A for
   staging.maynard-meadows.co.uk - check that a DNS record exists for
   this domain; DNS problem: NXDOMAIN looking up AAAA for
   this domain
I agree that the cert version is outdated, however, given the nature of these servers, I'd rather solve one issue at a time, so this will be added to my todo after I get the certificates renewed sucessfull (as I alss want to add this action to a cron job)
As you can see from this dump, we have a few domains on this service:
$sudo apache2ctl -t -D DUMP_VHOSTS
VirtualHost configuration:
*:80                   staging.burlington-place.co.uk (/etc/apache2/sites-enabled/vhosts.conf:36)
*:443                  is a NameVirtualHost
         default server staging.eastern-escape.co.uk (/etc/apache2/sites-enabled/vhosts.conf:3)
         port 443 namevhost staging.eastern-escape.co.uk (/etc/apache2/sites-enabled/vhosts.conf:3)
         port 443 namevhost staging.burlington-place.co.uk (/etc/apache2/sites-enabled/vhosts.conf:54)
         port 443 namevhost staging.alexandra-mansions.co.uk (/etc/apache2/sites-enabled/vhosts.conf:87)
         port 443 namevhost staging.thompson-staithe.co.uk (/etc/apache2/sites-enabled/vhosts.conf:120)
         port 443 namevhost staging.tollesbury-house.co.uk (/etc/apache2/sites-enabled/vhosts.conf:153)
         port 443 namevhost staging.narrows-place.co.uk (/etc/apache2/sites-enabled/vhosts.conf:186)
         port 443 namevhost staging.maynard-meadows.co.uk (/etc/apache2/sites-enabled/vhosts.conf:219)
         port 443 namevhost staging.simpsons-place.co.uk (/etc/apache2/sites-enabled/vhosts.conf:252)
Thanks again for your help in this, whilst I am not a total novice in this kind of operation, my lack of certain bits of knowledge as well as picking up someone else's work is making me tread carefully, so I do appreciate your patience.
Thanks,
Chris.
Oh boy, this looks kind of messy.
Your first cert uses --standalone and you stop Apache to allow that to work. Note this for later. But, it is for the domain staging.maynard-meadows.co.uk which no longer has an A or AAAA record in the public DNS. Do you still need a cert for this domain? It's a little confusing to see that domain name in a conf file named for staging.burlington-place.co.uk. Do you know how that happened?
Your second cert for staging.eastern-escape uses --webroot which requires Apache to handle the request. But, it looks like Apache is not restarted until after all the cert renewals are tried. I am going just by when the running post-hook command: service apache2 start is issued. And, this would explain why you get connection refused for the --webroot request.
Can you show output of this
sudo certbot certificates
You are not wrong. I've picked this up after my company not having a dev for a few months.
When I asked the question internally the initial response was 'We have a site for that?' so I'm going to go with no... and that pretty much sums up the situation I'm in right now.
Output of sudo certbot certificates :
$ sudo certbot certificates
Found the following certs:
  Certificate Name: staging.burlington-place.co.uk
    Domains: staging.alexandra-mansions.co.uk staging.burlington-place.co.uk staging.maynard-meadows.co.uk staging.narrows-place.co.uk staging.thompson-staithe.co.uk staging.tollesbury-house.co.uk
    Expiry Date: 2023-08-24 01:45:08+00:00 (INVALID: EXPIRED)
    Certificate Path: /etc/letsencrypt/live/staging.burlington-place.co.uk/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/staging.burlington-place.co.uk/privkey.pem
  Certificate Name: staging.eastern-escape.co.uk
    Domains: staging.eastern-escape.co.uk
    Expiry Date: 2023-10-19 04:28:42+00:00 (INVALID: EXPIRED)
    Certificate Path: /etc/letsencrypt/live/staging.eastern-escape.co.uk/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/staging.eastern-escape.co.uk/privkey.pem
Ouch! All names on all certs are EXPIRED.
Sounds like a good time to break whatever you have built and start over.
Can you show the entire contents of this file? It looks large so ideally use the upload file button. You may need to copy it to a temp folder as a .txt to upload it (I am not sure).
Also, there are 2 renewal conf files in the /etc/letsencrypt/renewal folder. Please paste output of both of those here too.
Hi Mike,
Thanks fro the reply and I hope you had a good weekend!
Here's the confs in the renewals folder: ( accound id's removed )
version = 0.27.0
archive_dir = /etc/letsencrypt/archive/staging.eastern-escape.co.uk
cert = /etc/letsencrypt/live/staging.eastern-escape.co.uk/cert.pem
privkey = /etc/letsencrypt/live/staging.eastern-escape.co.uk/privkey.pem
chain = /etc/letsencrypt/live/staging.eastern-escape.co.uk/chain.pem
fullchain = /etc/letsencrypt/live/staging.eastern-escape.co.uk/fullchain.pem
[renewalparams]
account = --snip--
authenticator = webroot
[[webroot_map]]
staging.eastern-escape.co.uk = /var/vhosts/staging.eastern-escape.co.uk/current/public
version = 0.27.0
archive_dir = /etc/letsencrypt/archive/staging.burlington-place.co.uk
cert = /etc/letsencrypt/live/staging.burlington-place.co.uk/cert.pem
privkey = /etc/letsencrypt/live/staging.burlington-place.co.uk/privkey.pem
chain = /etc/letsencrypt/live/staging.burlington-place.co.uk/chain.pem
fullchain = /etc/letsencrypt/live/staging.burlington-place.co.uk/fullchain.pem
[renewalparams]
account = --snip--
authenticator = standalone
pre_hook = service apache2 stop
post_hook = service apache2 start
And see attached the vhosts.conf file.
vhost-conf.txt (1.8 KB)
Thanks in advance!
Chris.
Shutting down the web server [just to get a cert] is a bit extreme.
I'd switch all of those to also use --webroot [like the first one].
I don't see "eastern" in the HTTP vhost config you provided:
<VirtualHost *:80>
  ServerName staging.burlington-place.co.uk
  ServerAlias staging.alexandra-mansions.co.uk staging.thompson-staithe.co.uk staging.tollesbury-house.co.uk staging.narrows-place.co.uk staging.maynard-meadows.co.uk staging.simpsons-place.co.uk
  DocumentRoot "/var/vhosts/staging.simpsons-place.co.uk/current/public"
  <Directory "/var/vhosts/staging.simpsons-place.co.uk/current/public">
    AllowOverride All
    Options -Indexes +FollowSymLinks
    Require all granted
  </Directory>
  RewriteEngine On
RewriteCond %{HTTPS} !=on
RewriteCond %{REQUEST_URI} !^/\.well-known
RewriteRule ^/(.*) https://%{SERVER_NAME}/$1 [R,L]
</VirtualHost>
I also see an unexpected redirection:
curl -Ii staging.burlington-place.co.uk/.well-known/acme-challenge/Test_File-1234
HTTP/1.1 302 Found
Date: Mon, 04 Dec 2023 10:21:25 GMT
Location: https://staging.burlington-place.co.uk/index.php
So... there must be another HTTP vhost config that is handling that "eastern" name [or as the HTTP vhost default].
Hi rg305.
I see what you mean!
Do you think at this point it's best to just remove the certs and start fresh? This whole setup looks a bit messed up.
Thoughts?
That's not as simple as you might imagine. Your Apache server will fail to start if it refers to cert files that don't exist. Recovering from that is probably harder than fixing your cert profiles.
Let's start by trying to renew just your staging.eastern domain. Can you show us what this does:
sudo certbot --renew --dry-run --cert-name staging.eastern-escape.co.uk
No.
It is almost never a good thing to start by deleting valid certs.
I get the warning
certbot: error: ambiguous option: --renew could match --renew-by-default, --renew-with-new-domains, --renew-hook
I assumed --renew was renew and got the following:
**          (The test certificates below have not been saved.)
**          (The test certificates above have not been saved.)
   Type:   unauthorized
   Detail: 3.10.33.189: Invalid response from
   https://staging.eastern-escape.co.uk/index.php: "<!DOCTYPE
   html>\n<html lang=\"en\" style=\"scroll-behavior: smooth;\">\n
   <head>\n        <meta charset=\"utf-8\">\n        <meta name=\""
I totally get that - I have to also look into this on our live server too so I'm just making sure we have the right procedure in place, whatever that may be. I appricate everyones patience in this.
Thanks
Chris.
The HTTP request was redirect to HTTPS [and incorrectly to a php file].
We need to look at the full config to see where that is happening.
Okay, Thanks, let me get that and get back to you
Can you check the public IP in the DNS?
This is one way to learn what it is. Then we compare to what is in the DNS
curl -4 https://ifconfig.io
Are you running the same version of Apache as your production domain?
Running apachectl -v
Staging server: 3.10.33.189
Live Server: 35.176.14.31
Server version: Apache/2.4.41 (Ubuntu)
Server built:   2023-10-26T13:54:09
Oh man! so the servers aren't even in alignment...
