Certbot - Running Certbot on a Machine that is Not the Web Server Means Challenges Fail
certbot certonly --standalone --email 584437830@qq.com -d gcenter.ol.ttigame.cn
    Domain: gcenter.ol.ttigame.cn
    Detail: Incorrect validation certificate for tls-sni-01 challenge.
    Requested
    bf23471475beb3cb85c1292df24a0d98.94b66852d73688b300e87fa0b0923198.acme.invalid
    from 121.201.7.19:443. Received 2 certificate(s), first certificate
    had names “doo.so, w.doo.so
nginx version: openresty/1.11.2.2
ubuntu-14.04
I am a newbie here…really really thanks if you could help
Did you run Certbot on your web server? That’s required for standalone mode to work - you can’t just run it on your laptop.
Other things to check if that doesn’t help.
thank you very much. I ran the command on my computer and the webserver is another one. the document on the official website didn’t mention things like this we need to give particular attention…e…maybe I didn’t see it
anyway thank you very much
and now I am trying another command on the webserver:
certbot certonly --webroot -w /var/www/example -d example.com -d www.example.com
Hi @JhonHarrison,
Maybe @SwartzCr, who has been dealing with documentation updates, can look into how to make clearer that Certbot is meant to be run directly on the web server (which has been an occasional problem for a number of users).
When you ran your newly updated command on the server, did you succeed or get any error message?
Hi @JhonHarrison
The commands you mention talk to the apache server / filepath and modify them. If you are not running them on your web server then when the Let’s Encrypt servers try to validate you own the domain they will fail
Andrei
