The operating system my web server runs on is (include version):Ubuntu server 18.04.4
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.27.0
Running certbot with builtin webserver I get an error. Starting a simple webserver manually works well.
certbot certonly --standalone --test-cert --preferred-challenges http-01 -d [my fqdn]
http-01 challenge for [my fqdn]
Waiting for verification…
Failed authorization procedure. [my fqdn] (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://[my fqdn]/.well-known/acme-challenge/9UehXhelUt606GErvJkGnwZFQfFGLN091B-AuxmbesA [my IP]: 503
Domain: [my fqdn]
Detail: Invalid response from
[my IP]: 503To fix these errors, please make sure that your domain name was
And now with a simple webserver:
python -m SimpleHTTPServer 80
Serving HTTP on 0.0.0.0 port 80 …
Now starting certbot without “standalone”:
certbot certonly --test-cert --preferred-challenges http-01 -d [my fqdn]
1: Spin up a temporary webserver (standalone)
2: Place files in webroot directory (webroot)
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 2
Input the webroot for access3.schwindt.eu: (Enter ‘c’ to cancel): /root/www
/etc/letsencrypt/live/[my fqdn]/fullchain.pem
/etc/letsencrypt/live/[my fqdn]/privkey.pem
Your cert will expire on 2020-08-18. To obtain a new or tweaked
version of this certificate in the future, simply run certbot
again. To non-interactively renew all of your certificates, run
“certbot renew”
Any ideas?
Thanks!
