Certbot renewal failing on pi 3 (using nginx as reverse proxy over apache )
www.saurabhorange.duckdns.org
sudo certbot renew --pre-hook “service nginx stop” --post-hook "service nginx start"
Processing /etc/letsencrypt/renewal/saurabhorange.duckdns.org.conf
Running pre-hook command: service nginx stop
http-01 challenge for saurabhorange.duckdns.org
http-01 challenge for www.saurabhorange.duckdns.org
Waiting for verification…
Attempting to renew cert from /etc/letsencrypt/renewal/saurabhorange.duckdns.org.conf produced an unexpected error: Failed authorization procedure. www.saurabhorange.duckdns.org (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://www.saurabhorange.duckdns.org/.well-known/acme-challenge/6S-QsmVl5SfK73MNE-6oL5ABtIIty-wvZ3Cjks4vtxI: Connection refused, saurabhorange.duckdns.org (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://saurabhorange.duckdns.org/.well-known/acme-challenge/4x-kp0G9kSqRncmFkQnde93qxBzr3g8SRCYod7wdkzc: Connection refused. Skipping.
/etc/letsencrypt/live/saurabhorange.duckdns.org/fullchain.pem (failure)
Running post-hook command: service nginx start
nginx and apache
debian jessie ( raspbian )
Try something like:
Alias /.well-known/acme-challenge /path-to-challenge
ProxyPass /.well-known/acme-challenge !
I partly disagree with this diagnosis.
is generally only appropriate for --standalone, yet the fact that the validation is using HTTP-01 makes me think that in fact --webroot was not used. (We really need to make the plugins log which plugin is being used for renewal so that we don't have to guess! :slight_smile:)
@saurabhvyas, why did you choose to use this particular form of the renew command, including those hook options? Did you find it in a particular tutorial or something? Do you have a reason to believe that your web server needs to be stopped before performing a renewal? What Certbot command did you use at the time you originally obtained your certificate?
When I try to connect to the site right now with HTTP, I see "400 Bad Request The plain HTTP request was sent to HTTPS port", which is a sign of a different kind of misconfiguration (although this specific error would not be directly seen by the Let's Encrypt CA if you use --pre-hook "service nginx stop" while renewing).
I am not able to understand this command , on just copy pasting it in exact form , I am getting an error , Alias command not found , I am a newbie
@saurabhvyas, where are you copying and pasting from?
What command did you use when you originally got your certificate for the first time?
I tried all renew commands listed on certbot section for nginx configuation , none of them worked , then i tried different combinations like stopping apache and nginx etc , Is there any way , I can systematically debug the error ?, there is a lot going on , and Its hard to debug …
Sure, could you start by posting the contents of /etc/letsencrypt/renewal/saurabhorange.duckdns.org.conf? I predict that it will say authenticator = webroot somewhere inside.
I dont remember exact command , but I remember following this
Here are the contents
version = 0.9.3
cert = /etc/letsencrypt/live/saurabhorange.duckdns.org/cert.pem
privkey = /etc/letsencrypt/live/saurabhorange.duckdns.org/privkey.pem
chain = /etc/letsencrypt/live/saurabhorange.duckdns.org/chain.pem
fullchain = /etc/letsencrypt/live/saurabhorange.duckdns.org/fullchain.pem
[renewalparams]
installer = None
account = 745848bb260e310de25ffa4e199ee2bb
webroot_path = /var/www/html,
[[webroot_map]]
www.saurabhorange.duckdns.org = /var/www/html
" @saurabhvyas, where are you copying and pasting from?
this , Alias /.well-known/acme-challenge /path-to-challenge
What command did you use when you originally got your certificate for the first time? "
as mentioned in certbot official website under debian jessie and nginx
Cool, thanks!
So the normal command to renew for most people is just certbot renew. However, I predict that that will fail in your current environment for a different reason.
This reason has to do with what happens if we go to your site in a browser: we get the error “400 Bad Request The plain HTTP request was sent to HTTPS port”. This means that your nginx configuration is mistakenly speaking HTTPS on port 80 as well as port 443. (It should speak HTTP on port 80 and HTTPS on port 443, since that’s what browsers expect, as well as what the Let’s Encrypt certificate authority expects to see when testing that you really control this domain name.)
Do you know what you might have done in your nginx configuration that could have produced this behavior in nginx? If not, could you please also post your nginx configuration files?
Thanks for giving a direction for research , Last time ( no 400 bad request ) , it was working perfectly , and I do have backup of that time , so I will investigate and get back to you .
when you go to https://www.saurabhorange.duckdns.org , It works , but when I type http , It doesnt work , I think even earlier , I was using https only , anyway here is the github gist containing current nginx config file and apache2 config file .
Let me know if you find any irregularities
If you haven’t already, I would try:
sudo certbot --nginx
I installed certbot nginx plugin using apt-get , then tried that command , it did work , but it threw another error
" pi@orangepi:~ $ sudo certbot --nginx
Could not open file: /etc/nginx/sites-enabled/rpicam
1: saurabhorange.duckdns.org
2: www.saurabhorange.duckdns.org
blank to select all options shown (Enter 'c' to cancel):1
tls-sni-01 challenge for saurabhorange.duckdns.org
nginx restart failed:
nginx: [emerg] could not build the server_names_hash, you should increase server_names_hash_bucket_size: 64
Honestly, I would upgrade your nginx. The 400 page is reporting that it’s running 1.6.2, which was released in 2014. That config file looks valid to me on the redirect, although I don’t see any webroot setup under the .well-known location.
I tried upgrading , but according to my current operating system , raspbian jessie , It is the latest version , I couldn’t find any tutorial on how to add backports in sources file , in order to install latest nginx on raspberry pi , If I cannot resolve this in a straightforward way , I will try to backup everything and start with fresh installanation and new certification using certbot
