Whoa I think we just hit paydirt, got a lot thrown back at me...
Saving debug log to C:\Certbot\log\letsencrypt.log
Renewing an existing certificate for foundry.koodgarma.com
Please deploy a DNS TXT record under the name:
_acme-challenge.foundry.koodgarma.com.
with the following value:
*<<REMOVED A LONG STRING IN CASE THIS IS SUPPOSED TO BE SECRET>>*
Before continuing, verify the TXT record has been deployed. Depending on the DNS
provider, this may take some time, from a few seconds to multiple minutes. You can
check if it has finished deploying with aid of online tools, such as the Google
Admin Toolbox: https://toolbox.googleapps.com/apps/dig/#TXT/_acme-challenge.foundry.koodgarma.com.
Look for one or more bolded line(s) below the line ';ANSWER'. It should show the
value(s) you've just added.
Press Enter to Continue
YES! Here is what came after that... I think the next step is to copy and paste the cert and key pem files to my Foundry VTT folder right?
Certificate is saved at: C:\Certbot\live\foundry.koodgarma.com\fullchain.pem
Key is saved at: C:\Certbot\live\foundry.koodgarma.com\privkey.pem
This certificate expires on 2022-06-09.
NEXT STEPS:
This certificate will not be renewed automatically. Autorenewal of --manual certificates requires the use of an authentication hook script (--manual-auth-hook) but one was not provided. To renew this certificate, repeat this same certbot command before the certificate's expiry date.
