alleninvestmentsllc.com www.alleninvestmentsllc.com
sudo certbot renew --debug-challenges
Processing /etc/letsencrypt/renewal/alleninvestmentsllc.com.conf
Found credentials in shared credentials file: ~/.aws/credentials
Plugins selected: Authenticator dns-route53, Installer None
dns-01 challenge for alleninvestmentsllc.com
dns-01 challenge for www.alleninvestmentsllc.com
Starting new HTTPS connection (1): route53.amazonaws.com
Waiting 10 seconds for DNS changes to propagate
Waiting for verification…
Challenges loaded. Press continue to submit to CA. Pass “-v” for more info about
challenges.
Resetting dropped connection: route53.amazonaws.com
Attempting to renew cert (alleninvestmentsllc.com) from /etc/letsencrypt/renewal/alleninvestmentsllc.com.conf produced an unexpected error: Failed authorization procedure. alleninvestmentsllc.com (dns-01): urn:ietf:params:acme:error:dns :: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.alleninvestmentsllc.com - check that a DNS record exists for this domain, www.alleninvestmentsllc.com (dns-01): urn:ietf:params:acme:error:dns :: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.www.alleninvestmentsllc.com - check that a DNS record exists for this domain. Skipping.
/etc/letsencrypt/live/alleninvestmentsllc.com/fullchain.pem (failure)
Domain: alleninvestmentsllc.com
Type: None
Detail: DNS problem: NXDOMAIN looking up TXT for
exists for this domainDomain: www.alleninvestmentsllc.com
Type: None
apache2 -v
Server version: Apache/2.4.18 (Ubuntu)
Server built: 2019-10-08T13:31:25
Linux ip-172-26-13-86 4.4.0-1098-aws #109-Ubuntu SMP Fri Nov 8 09:30:18 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
aws lightsail
no
certbot 0.31.0
When I run it, I see that the dns TXT entries were created.
