Letsencrypt renew SSL failure with DNS problem: NXDOMAIN looking up TXT for _acme-challenge
hi guys i have a problem while performing ssl renewal
My domain is: kontrakhukum.com
I ran this command: sudo certbot certonly --cert-name kontrakhukum.com --dns-cloudflare --dns-cloudflare-credentials /etc/letsencrypt/cloudflareapi.cfg --server https://acme-v02.api.letsencrypt.org/directory -d “*.kontrakhukum.com” -d kontrakhukum.com
dns-01 challenge for kontrakhukum.com
Unsafe permissions on credentials configuration file: /etc/letsencrypt/cloudflareapi.cfg
Starting new HTTPS connection (1): api.cloudflare.com
Waiting 10 seconds for DNS changes to propagate
Waiting for verification…
Challenge failed for domain kontrakhukum.com
    Domain: kontrakhukum.com
    Type: dns
    Detail: DNS problem: NXDOMAIN looking up TXT for
    _acme-challenge.kontrakhukum.com - check that a DNS record exists
    for this domain
My web server is (include version): nginx 1.17.6
The operating system my web server runs on is (include version): cent os 7
My hosting provider, if applicable, is: godaddy
I can login to a root shell on my machine (yes or no, or I don’t know): no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 1.4.0
Your domain is not setup to use Cloudflare’s nameservers, it is using GoDaddy’s.
If you want to use Cloudflare, you need to login to your GoDaddy control panel and change the nameserver registration to those that Cloudflare has allocated you: https://www.godaddy.com/help/change-nameservers-for-my-domains-664
If you’ve already done that, you probably just need to wait it out, because the change hasn’t propagated to the .com nameservers yet.
Thanks for your insights about this, first i thought this was a problem only with txt challenge, but it turns out to changing the nameservers. I expect to renew my wildcard ssl with cloudflare because i think it will solve limit to issued the certificate.
