My domain is: netbox.over.ru
I ran this command: certbot --test-cert -d netbox.over.ru
Requesting a certificate for netbox.over.ru
Domain: netbox.over.ru
Detail: 88.212.205.9: Invalid response from http://netbox.over.ru/.well-known/acme-challenge/-PGCpIweswZ274_JX8CdhcaEj6Wtte85EPvT98OFML8: 404
My web server is (include version): nginx/1.26.2
The operating system my web server runs on is (include version): FreeBSD 14.2-RELEASE
My hosting provider, if applicable, is: self-hosted
certbot 4.0.0
I'm 100% sure that paths are correct.
root@gab2:/usr/local/www # ls -ls /usr/local/www/nginx/.well-known/acme-challenge/test
1 -rw-r--r-- 1 root wheel 29 May 22 22:35 /usr/local/www/nginx/.well-known/acme-challenge/test
root@gab2:/usr/local/www # curl http://netbox.over.ru/.well-known/acme-challenge/test
Thu May 22 22:35:57 MSK 2025
Looks like certbot puts challenge in some wrong place.
I explicitly specify root for .well-known
listen 80;
server_name netbox.over.ru;
location /.well-known {
root /usr/local/www/nginx;
proxy_pass http://10.145.1.38;
