yum install certbot-apache
Error: Package: python2-certbot-apache-0.22.0-1.el7.noarch (epel)
Requires: mod_ssl
Apache - 2.4.29
Centos 7 (kernel 3.10.0-693.17.1.el7.x86_64)
DigitialOcean
I can login to a root shell on my machine (yes or no, or I donβt know):
Yes
Iβm using a control panel to manage my site (no, or provide the name and version of the control panel): I have lets-encrypt for cpanel option but it prompts error telling me to contact host ( I know this is old and renamed or whatever so I Donβt use it)
I'll need to see the entire yum output to diagnose this issue properly. Please copy and paste everything yum outputs, from the big tree of arrows all the way down to the full error. If it's too long for the forum you can use a service like pastebin.com and link to it here. Thanks!
updates: mirror.atlanticmetro.net
Resolving Dependencies
β> Running transaction check
β> Package python2-certbot-apache.noarch 0:0.22.0-1.el7 will be installed
β> Processing Dependency: mod_ssl for package: python2-certbot-apache-0.22.0-1. el7.noarch
β> Processing Dependency: python-augeas for package: python2-certbot-apache-0.2 2.0-1.el7.noarch
β> Package python-augeas.noarch 0:0.5.0-2.el7 will be installed
β> Processing Dependency: augeas-libs for package: python-augeas-0.5.0-2.el7.noarch
β> Processing Dependency: mod_ssl for package: python2-certbot-apache-0.22.0-1.el7.noarch
β> Package augeas-libs.x86_64 0:1.4.0-2.el7_4.2 will be installed
β> Finished Dependency Resolution
Requires: mod_ssl
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
[root~]#
cPanel packages its own Apache rpms (via its EasyApache mechanism). e.g. You may find that mod_ssl is provided by ea-apache24-mod_ssl-2.4.29-9.9.1.cpanel.x86_64 rather than what you would expect from a standard CentOS environment.
For this specific reason, I am not sure whether it is possible/advisable to install Certbot (specifically, certbot-apache) from repos. Certbot (from EPEL) assumes that you have a standard CentOS environment, but in the case of cPanel, you definitely don't.
It would be too risky to try and use the --installer apache with cPanel anyway, since cPanel manages/distills the httpd configuration on its own manually in a very specific manner, and manual changes by Certbot would get wiped out at next distillation. So you don't need certbot-apache at all.
Perhaps instead try the portable certbot-auto, but I would not use it in any mode besides certonly, and you will need to write a manual certificate installation hook using the uapi command against SSL install_ssl.
As the author, I can provide some info:
It's a commercial plugin, the most likely reason to see that message is if you had a trial and it expired
It's still actively maintained
It does not support wildcards yet, but support for it is coming this week . It fully supports wildcards.
The built-in AutoSSL feature in cPanel does not support wildcards at this time
