Certbot not renewing certificates, timing out on challenges
My domain is: westconn.com.au
Processing /etc/letsencrypt/renewal/westconn.com.au.conf
Non-interactive renewal: random delay of 366.726563028 seconds
Renewing an existing certificate for westconn.com.au and 2 more domains
http-01 challenge for ph.westconn.com.au
http-01 challenge for westconn.com.au
http-01 challenge for www.westconn.com.au
Using the webroot path /home/ph for all unmatched domains.
Challenge failed for domain ph.westconn.com.au
Challenge failed for domain westconn.com.au
Challenge failed for domain www.westconn.com.au
Failed to renew certificate westconn.com.au with error: Some challenges have failed.
/etc/letsencrypt/live/westconn.com.au/fullchain.pem (failure)
My web server is (include version): Apache version 2.4.6
The operating system my web server runs on is (include version): CentOS Linux 7.9.2009 (EOL reached)
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): webmin
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.11.0
After many attempts I have now been able to renew my certificates by turning off redirect for the required virtual domains,
Non-interactive renewal: random delay of 92.9884762855 seconds
new certificate deployed without reload, fullchain is
Congratulations, all renewals succeeded:
/etc/letsencrypt/live/westconn.com.au/fullchain.pem (success)
For future it would be better to get a solution that will auto update certificates, reading in the forums seem to indicate the problem is caused elsewhere
My redirects were set in the apache configuration
<VirtualHost *:80>
    DocumentRoot /var/www/html
    ServerName www.westconn.com.au
    <Directory "/var/www/html">
        allow from all
        Redirect / https://westconn.com.au/
        Options None
        Require all granted
    </Directory>
</VirtualHost>
Currently it appears that the website has not been working since the certificates expired and is still not loading pages, which is currently of little importance, but also some of the email clients are not working, as we are trying to migrate all to ssl, that is of more importance
That's because your server is accessible over HTTP port 80, but for some reason HTTPS port 443 is being blocked.
so easy when I am looking for the problem at the right port
thank you
