My domain is: market-place.quymanh.online
My web server is (include version): nginx-1.27.0
The operating system my web server runs on is (include version): AWS Linux
i don't know what's wrong with my configuration nginx below at default.conf, Everything is oke but maybe the nginx not work. I checked everything about the cert keys is Ok but my website not work :<.
upstream server {
server server:3333;
listen 443 ssl;
listen [::]:443 ssl ipv6only=on;
server_name market-place.quymanh.online www.market-place.quymanh.online;
root /usr/share/nginx/html;
server_tokens off;
# use the certificates
ssl_certificate /etc/letsencrypt/live/market-place.quymanh.online/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/market-place.quymanh.online/privkey.pem;
ssl_session_cache shared:le_nginx_SSL:10m;
ssl_session_timeout 1440m;
ssl_session_tickets off;
ssl_prefer_server_ciphers on;
ssl_ciphers "ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384";
ssl_dhparam /etc/ssl/certs/dhparam-2048.pem;
add_header Strict-Transport-Security "max-age=31536000; includeSubdomains";
# Define the specified charset to the “Content-Type” response header field
charset utf-8;
index index.html index.htm;
try_files $uri /index.html =404;
# Proxy requests to the Node.js backend
location /api/ {
proxy_pass http://server/api/;
proxy_http_version 1.1;
proxy_set_header Host $host;
listen 80 default_server;
