Certbot/letsencrypt querying wrong
My domain is: echannel.se
sudo certbot certonly --test-cert --manual
Please enter in your domain name(s) (comma and/or space separated)  (Enter 'c'
to cancel): echannel.se
http-01 challenge for echannel.se
NOTE: The IP of this machine will be publicly logged as having requested this
certificate. If you're running certbot in manual mode on a machine that is not
your server, please ensure you're okay with that.
Are you OK with your IP being logged?
(Y)es/(N)o: Y
Create a file containing just this data:
... Stuff hidden ....
Press Enter to Continue
Failed authorization procedure. echannel.se (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from https://linux-wk.wk.se/.well-known/acme-challenge/6s9U4Wqf_IQogrDBY5H-FfSZN2aqE0X7L2v-zgLbmOk [2001:67c:2b58:1::53]: "<!DOCTYPE HTML PUBLIC \"-//IETF//DTD HTML 2.0//EN\">\n<html><head>\n<title>404 Not Found</title>\n</head><body>\n<h1>Not Found</h1>\n<p"
   Domain: echannel.se
   Type:   unauthorized
   Detail: Invalid response from
Manual
Ubuntu
Yes
No
certbot 0.31.0
As it can be seen, I am trying to generate certificate for domain echannel.se, but LE sends the request to linux-wk.wk.se.
I tried dns resolver got my IP address. Also unboundtest also returns my IP address.
Hi @tejainece
checking your configuration there is such a redirect ( https://check-your-website.server-daten.de/?q=echannel.se ):
Your ip addresses (ipv4 and ipv6):
echannel.se A 195.67.148.135 Saltsjö-Duvnäs/Stockholm/Sweden (SE) - TELIANET Hostname: 195-67-148-135.customer.telia.com yes 1 0
AAAA 2001:67c:2b58:1::27 Stockholm/Sweden (SE) - Webbkonsulterna AB yes
www.echannel.se A 195.67.148.135 Saltsjö-Duvnäs/Stockholm/Sweden (SE) - TELIANET Hostname: 195-67-148-135.customer.telia.com yes 1 0
Ipv6 works. But there are curious redirects:
http://echannel.se/
2001:67c:2b58:1::27 302 http://parking.wk.se 0.110 D
http://www.echannel.se/
2001:67c:2b58:1::27 302 http://parking.wk.se 0.096 D
http://echannel.se/
195.67.148.135 -2 1.110 V
ConnectFailure - Unable to connect to the remote server No connection could be made because the target machine actively refused it 195.67.148.135:80
195.67.148.135 -2 1.090 V
http://parking.wk.se 200 0.187 H
https://echannel.se/
2001:67c:2b58:1::27 302 http://parking.wk.se 3.936 N
Certificate error: RemoteCertificateNameMismatch
https://www.echannel.se/
2001:67c:2b58:1::27 302 http://parking.wk.se 3.360 N
195.67.148.135 -2 1.094 V
ConnectFailure - Unable to connect to the remote server No connection could be made because the target machine actively refused it 195.67.148.135:443
http://echannel.se/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
2001:67c:2b58:1::27 301 https://linux-wk.wk.se/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 0.106 E
Visible Content: Moved Permanently The document has moved here .
http://www.echannel.se/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
2001:67c:2b58:1::27 301 https://linux-wk.wk.se/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 0.093 E
195.67.148.135 -2 1.096 V
Visible Content:
Visible Content:
https://linux-wk.wk.se/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 404 3.453 A
Not Found
Visible Content: Not Found The requested URL /.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de was not found on this server.
http + ipv6 is redirected to a parking site. And http + ipv6 + /.well-known/acme-challenge is redirected to linux-wk.wk.se.
Is this your hoster? Or is this another domain you own?
Letsencrypt follows these redirects, so that may not work. It may work, if the linux-domain is your own domain.
Thanks for the quick response!
I don’t have an IPv6 address. The IPv4 address is 195.67.148.135 as seen above. wk.se (like godaddy) is the service from where I got the domain.
LE seems to hit 195.67.148.135 before it contacts https://linux-wk.wk.se. However it says No connection could be made because the target machine actively refused it. Any idea why this occurs?
 http://echannel.se/
• http://www.echannel.se/
For example, you can reach this webpage: http://echannel.se/hello.txt
You have an ipv6 address - https://check-your-website.server-daten.de/?q=echannel.se
Same picture again:
And Letsencrypt prefers ipv6, so that's critical.
Ipv4 + http answers now, but ipv6 has the same redirect.
http://echannel.se/
2001:67c:2b58:1::27 302 http://parking.wk.se 0.097 D
http://echannel.se/
195.67.148.135 200 0.063 H
195.67.148.135 200 0.064 H
http://parking.wk.se 200 0.283 H
2001:67c:2b58:1::27 302 http://parking.wk.se 3.500 N
2001:67c:2b58:1::27 302 http://parking.wk.se 3.326 N
2001:67c:2b58:1::27 301 https://linux-wk.wk.se/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 0.094 E
195.67.148.135 404 0.060 A
File not found
Visible Content: Error response Error code 404. Message: File not found. Error code explanation: 404 = Nothing matches the given URI.
195.67.148.135 404 0.063 A
File not found
Not Found
So that can't work.
Check your DNS entries and remove the not working ipv6 address.
Then recheck your domain with the online tool to see, if the ipv6 is gone.
