Certbot is already running
My domain is: no
I ran this command: I restored my server snapshot, and before the restore my Nginx proxy manager had already requested the certificates via Cloudflaer using *.yydy.link and yydy.link, but after I restored the previous server snapshot, I reused the Nginx proxy manager to send the certificate to the Let's Encrypt The following error occurs when applying for the certificates.
log:Error: Command failed: certbot certonly --config "/etc/letsencrypt.ini" --work-dir "/tmp/letsencrypt-lib" --logs-dir "/tmp/letsencrypt-log" --cert-name "npm-45" --agree-tos --email "vip@ypcloud.space" --domains "*.yydy.link,yydy.link" --authenticator dns-cloudflare --dns-cloudflare-credentials "/etc/letsencrypt/credentials/credentials-45"
Another instance of Certbot is already running.
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /tmp/certbot-log-0_tp1hz3/log or re-run Certbot with -v for more details.
at ChildProcess.exithandler (node:child_process:402:12)
at ChildProcess.emit (node:events:513:28)
at maybeClose (node:internal/child_process:1100:16)
at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5)
My web server is (include version): yydy.link
The operating system my web server runs on is (include version): Linux Young-Docker 6.2.0-25-generic #25-Ubuntu SMP PREEMPT_DYNAMIC Fri Jun 16 17:05:07 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
My hosting provider, if applicable, is:Local deployment; VMware
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): Linux Young-Docker 6.2.0-25-generic #25-Ubuntu SMP PREEMPT_DYNAMIC Fri Jun 16 17:05:07 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
How do you revoke a previously duplicated certificate?
# Workaround
Revoking a perfectly fine certificate is almost never the answer and it certainly isn't for this situation. It isn't a "#workaround", it is not a solution.
That said, I have no idea how to debug nor fix this issue when Nginx Proxy Manager is being used.
Also, why answer "no" for the domain name question? That's kinda silly, no? It's not a yes or no question..
his domain is yydy.link, he put that on server question but looks like it's firewalled, so he's using DNS challange over cloudflare.
there is another post next it about lockfile, check it too
