sittingduckpodcast.com (probably not working currently, but kinda beside the point for this issue)
certbot certificates
It hangs
Apache/2.4.37
AlmaLinux 8.5
DigitalOcean VPS
Yes
No
Cannot determine certbot version. Snappy is 2.53.4-1.el8.
I think this is probably an issue with Snappy, but figure this is as good a place to ask as any. I went to add a new certificate for the above-named domain, but the command hung. I next tried certbot certificates and this also hung!
Thinking this very odd, I next tried to see if Certbot had been updated recently, which was when I encountered the problem that the snap command also hangs on every command except help.
I had just done a dnf update on the server and rebooted it. The /var/log/letsencrypt.log showed there had been successful activity within the 24 hours before I discovered the issue, but there has been none since (now several days). I have confirmed the snapd daemon is running and can find no errors in /var/log/messages relating to it, nor with journalctl.
I have no clues as to what is causing this, so am rather stuck. The only next step I can think of without any further clues is to uninstall and reinstall Snappy and certbot. Not sure what this will mean for my other sites (on the same server) that currently have valid certificates.
