My web server is (include version): Apache/2.4.18
PRETTY_NAME=“Ubuntu 16.04.3 LTS”
My hosting provider, if applicable, is: AWS
I can login to a root shell on my machine (yes or no, or I don’t know): yep
Guys, it’s very strange! the response that has "
404 Not Found
" is the error from Nginx server, and we run Apache, and apache log files, and tcpdump/tcpflow do not show any attempts to actually get the challenge file, the LE both live and staging endpoints go to some very wrong IP address. I checked DNS from several places, all looks OK. If I try accessing well-known URL using regular browser all is OK. It’s the first time I encounter this problem, though we have/had dozens of domains.
Starting new HTTPS connection (1): acme-staging-v02.api.letsencrypt.org
http-01 challenge for pag-crowd.nangasystems.com
Using the webroot path /var/www/html for all unmatched domains.
Waiting for verification…
Failed authorization procedure. pag-crowd.nangasystems.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://pag-crowd.nangasystems.com/.well-known/acme-challenge/jqwgaqjwNrswokXCvVLvRmV9MUcDAIQbWjRtloLiTKQ: "<html>
<head><title>404 Not Found</title></head>
<body bgcolor="white">
<center><h1>404 Not Found</h1></center>
<hr><center>"
Your account credentials have been saved in your Certbot
Your domain has IPv4 and IPv6 records, the A record points to an Apache web server and the AAAA record points to a nginx web server. As Let’s Encrypt prefers IPv6 over IPv4, it is trying to reach the challenge using your nginx web server and seems you are not using it to issue your cert.
Fix your IPv6 conf or if you are not using it, remove the AAAA record for your domain.
