Hi, I have problem with my certs, like for example tw.ppm.meteygana.pe . I check the permision of folder but I still see the errors in nginx log file:
[error] 1383405#1383405: *2865399 open() "/var/www/html/letsencrypt/.well-known/acme-challenge/ZQ5LjWiKwVsnqmJOKRYATsfuwXcXayb_cOQFuUFr_ec" failed (2: No such file or directory), client: 23.178.112.105, server: tw.ppm.meteygana.pe, request: "GET /.well-known/acme-challenge/ZQ5LjWiKwVsnqmJOKRYATsfuwXcXayb_cOQFuUFr_ec HTTP/1.1", host: "tw.ppm.meteygana.pe"
but the folder has permissions and the link is open: http://tw.ppm.meteygana.pe/.well-known/acme-challenge/ZQ5LjWiKwVsnqmJOKRYATsfuwXcXayb_cOQFuUFr_ec
I don't know where is problem, And this happend in this month. before all were running without issues
tw.ppm.meteygana.pe
certbot -v --nginx --no-redirect -d tw.ppm.meteygana.pe -w /var/www/html/letsencrypt/
Please choose an account
*1: **********@
*2: **********@
Requesting a certificate for tw.ppm.meteygana.pe
http-01 challenge for tw.ppm.meteygana.pe
Challenge failed for domain tw.ppm.meteygana.pe
- Domain: tw.ppm.meteygana.pe*
- Type: unauthorized*
- Detail: 201.201.87.202: Invalid response from http://tw.ppm.meteygana.pe/.well-known/acme-challenge/ZQ5LjWiKwVsnqmJOKRYATsfuwXcXayb_cOQFuUFr_ec: 404*
Ubuntu 20.04.5 LTS nginx version: nginx/1.18.0
no
commands:
- certbot
services:
certbot.renew: oneshot, enabled, inactive
snap-id: wy7i66qPx4neXr6m9rTh7Y40h8EhtZFh
tracking: latest/stable
refresh-date: 9 days ago, at 09:24 -07
channels:
latest/stable: 2.7.1 2023-10-10 (3390) 47MB classic
latest/candidate: ↑
latest/beta: 2.7.1 2023-10-10 (3390) 47MB classic
latest/edge: 2.8.0.dev0 2023-10-19 (3419) 47MB classic
installed: 2.7.1 (3390) 47MB classic
nginx configuere site::
tw.ppm.meteygana.pe.conf
server{
listen 80;
server_name tw.ppm.meteygana.pe;
access_log /var/log/nginx/tw.ppm.meteygana.pe.access.log;
auth_basic off;
root /var/www/html/letsencrypt;
try_files $uri $uri/ /index.html;
allow all;
$ ll /var/www/html/letsencrypt/
total 16
drwxr-xr-x+ 3 www-data www-data 4096 Oct 19 12:24 ./
drwxr-xr-x 13 www-data www-data 4096 Aug 17 12:03 ../
-rw-r-xr--+ 1 www-data www-data 2 Oct 19 12:24 index.html*
drwxr-xr-x+ 3 www-data www-data 4096 Oct 19 10:06 .well-known/
ll /var/www/html/letsencrypt/.well-known/acme-challenge/
total 12
drwxr-xrwx+ 2 www-data www-data 4096 Oct 19 14:18 ./
drwxr-xr-x+ 3 www-data www-data 4096 Oct 19 10:06 ../
-rw-r-xr--+ 1 www-data www-data 3 Oct 19 10:59 index.html*
-rw-rw-r-- 1 www-data www-data 0 Oct 19 14:26 ZQ5LjWiKwVsnqmJOKRYATsfuwXcXayb_cOQFuUFr_ec
DNS:
$nslookup tw.ppm.meteygana.pe 8.8.8.8
Server: 8.8.8.8
Address: 8.8.8.8#53
Non-authoritative answer:
Address: 201.201.87.202
