Certbot failed to authenticate some domains (authenticator: nginx). The Certificate Authority reported these problems
Help me!! When I run sudo certbot -v --nginx -d trippae.com, it error:
Domain: api.trippae.com
Detail: 2606:4700:3035::ac43:d9d1: Invalid response from https://api.trippae.com/.well-known/acme-challenge/cKmXhCMDk-XU1PlKBu2o4RRSd5a_swt5UNzine06m8c: 522
Welcome @tuandh7x
Your domain DNS is proxied in Cloudflare so uses their CDN. The 522 error says the Cloudflare Edge cannot connect to your Origin server. See this Cloudflare community topic
Note this 522 error is not unique to Let's Encrypt. I get the same error trying to reach your home page. Example test using IPv6:
curl -I6 https://trippae.com
HTTP/2 522
date: Fri, 29 Jul 2022 15:06:49 GMT
server: cloudflare
cf-ray: 7326c1f9eba38200-IAD
(other headers omitted)
