Certbot "Exiting abnormally" if CSR uses PrivKey with ec parameters encoded (=param_enc explicit)
Using manual LE cert generation
    certbot-auto certonly \
    --server https://acme-staging.api.letsencrypt.org/directory \
    --standalone --standalone-supported-challenges tls-sni-01 \
    --csr=./example.com.csr.der ...
If the CSR has been generated with a separately-seeded privkey, with NO explicit params encoded in the key
    openssl ecparam -name secp384r1 -param_enc explicit -outform pem -out ./params.pem
    openssl ecparam -genkey -name secp384r1 -noout -in ./params.pem -out ./privkey.pem
generating a CSR as
    Certificate Request:
        Data:
            Version: 0 (0x0)
            Subject: C=US, ST=NewYork, L=NewYork, O=example.com, OU=example.com, CN=example.com/emailAddress=noreply@example.com
            Subject Public Key Info:
                Public Key Algorithm: id-ecPublicKey
                    Public-Key: (384 bit)
                    pub:
                    ASN1 OID: secp384r1
                    NIST CURVE: P-384
            Attributes:
            Requested Extensions:
                X509v3 Subject Alternative Name:
                    DNS:example.com
        Signature Algorithm: ecdsa-with-SHA512
then the LE cert generation is successful
 - Congratulations! Your certificate and chain have been saved at
   /tmp/example.com/0001_chain.pem.
   Your cert will expire on 2016-11-06. To obtain a new or tweaked
   version of this certificate in the future, simply run certbot-auto
   again. To non-interactively renew *all* of your certificates, run
   "certbot-auto renew"
But if the CSR has been generated with explicit parameter encoding, and self-seeding,
    openssl ecparam -genkey -name secp384r1 -noout -out ./privkey.pem \
     -param_enc explicit \
so that the generated CSR is
        Data:
            Version: 0 (0x0)
                    pub:
                    Field Type: prime-field
                    Prime:
                        00:...
                    A:
                        00:...
                    B:
                        00:...
                    Generator (uncompressed):
                        04:...
                    Order:
                        00:...
                    Cofactor:  1 (0x1)
                    Seed:
                        a4:...
            Attributes:
                    DNS:example.com
an error’s returned
    An unexpected error occurred:
    The request message was malformed :: Error parsing certificate request. Extensions in the CSR marked critical can cause this error: https://github.com/letsencrypt/boulder/issues/565
where
cat /var/log/letsencrypt/letsencrypt.log
     2016-08-08 16:33:04,568:DEBUG:acme.client:Received response <Response [400]> (headers: {'Content-Length': '217', 'Boulder-Request-Id': '4...', 'Expires': 'Wed, 08 Aug 2016 16:33:05 GMT', 'Server': 'nginx', 'Connection': 'close', 'Cache-Control': 'max-age=0, no-cache, no-store', 'Pragma': 'no-cache', 'Boulder-Requester': '2...', 'Date': 'Wed, 10 Aug 2016 16:33:05 GMT', 'Content-Type': 'application/problem+json', 'Replay-Nonce': '...'}): '{\n  "type": "urn:acme:error:malformed",\n  "detail": "Error parsing certificate request. Extensions in the CSR marked critical can cause this error: https://github.com/letsencrypt/boulder/issues/565",\n  "status": 400\n}'
    2016-08-10 16:33:04,569:DEBUG:certbot.main:Exiting abnormally:
      File "/root/.local/share/letsencrypt/bin/letsencrypt", line 11, in <module>
        sys.exit(main())
      File "/root/.local/share/letsencrypt/lib/python2.7/site-packages/certbot/main.py", line 744, in main
      File "/root/.local/share/letsencrypt/lib/python2.7/site-packages/certbot/main.py", line 558, in obtain_cert
        _csr_obtain_cert(config, le_client)
      File "/root/.local/share/letsencrypt/lib/python2.7/site-packages/certbot/main.py", line 527, in _csr_obtain_cert
        certr, chain = le_client.obtain_certificate_from_csr(config.domains, csr, typ)
      File "/root/.local/share/letsencrypt/lib/python2.7/site-packages/certbot/client.py", line 228, in obtain_certificate_from_csr
        authzr)
      File "/root/.local/share/letsencrypt/lib/python2.7/site-packages/acme/client.py", line 319, in request_issuance
        headers={'Accept': content_type})
      File "/root/.local/share/letsencrypt/lib/python2.7/site-packages/acme/client.py", line 656, in post
        return self._check_response(response, content_type=content_type)
      File "/root/.local/share/letsencrypt/lib/python2.7/site-packages/acme/client.py", line 572, in _check_response
        raise messages.Error.from_json(jobj)
    Error: urn:acme:error:malformed :: The request message was malformed :: Error parsing certificate request. Extensions in the CSR marked critical can cause this error: https://github.com/letsencrypt/boulder/issues/565
The referenced bug
**_Golang errors on extensions marked critical #565_**
[https://github.com/letsencrypt/boulder/issues/565](https://github.com/letsencrypt/boulder/issues/565)
addresses parsing problems, but is Golang, not python related, and doesn’t mention the params encoding specifically.
Is there a specific reason that privkey parameter encoding is DISALLOWED in LE, or is this (still) a bug?
The CA/B Baseline Requirements state that ECC certs must use the NIST P‐256, P‐384, or P‐521 curves.
Ok, and what point are you making?
As you can see from my OP
-name secp384r1
where
openssl ecparam -list_curves | grep secp384r1
  secp384r1 : NIST/SECG curve over a 384 bit prime field
and at https://www.ietf.org/rfc/rfc5480.txt
2.1.1.1.  Named Curve
The NIST-named curves are:
     -- Note that [FIPS186-3] refers to secp192r1 as P-192, secp224r1 as
     -- P-224, secp256r1 as P-256, secp384r1 as P-384, and secp521r1 as
     -- P-521.
i.e. 'secp384r1' == 'P-384'
This seems like it might be an issue with the upstream Golang x509 package that Boulder uses to process CSRs.
I created a CSR (test.ecparam.csr) following your instructions and used it with this test program:
package main
import (
	"crypto/x509"
	"fmt"
	"io/ioutil"
func main() {
	bytes, _ := ioutil.ReadFile("test.ecparam.csr")
	req, err := x509.ParseCertificateRequest(bytes)
	if err != nil {
		fmt.Printf("Err: %s\n", err)
	fmt.Printf("Req: %#v\n", req)
On go version go1.6.2 linux/amd64 this produces:
Err: asn1: structure error: tags don't match (16 vs {class:0 tag:13 length:45 isCompound:true}) {optional:false explicit:false application:false defaultValue:<nil> tag:<nil> stringType:0 timeType:0 set:false omitEmpty:false} certificateRequest @2
Req: (*x509.CertificateRequest)(nil)
@cpu
So the python error from logs is simply a red-herring here?
I agree the text is a little bit vague/misleading. Certbot is informing you of the error response from Boulder, generated because it was unable to parse the CSR.
The upstream x509 library does not support explicit parameter encoding and regardless of whether it is added there we likely won’t support it in Boulder.
Is there a specific use case that is pushing you towards using explicit encoding that can’t be met in another fashion?
@cpu
I'd suggest it's a bit more than that ... there's simply no indication of it NOT being a python problem. In any case, the 'log output' is generally not helpful -- other than, of course, the "maybe go see this bug" test.
The use case is simply that defined by my standard workflow/process which includes
  • no separate ec params generation and storage
  • parameter encoding in the key to accommodate Openssl v < (iirc) 1.0.2 curve usage.
I'm already having to modify my processes to accommodate LE since neither EC automation nor parallel-algo cert generation are currently available via certbot, and have to be done manually.
that can't be met in another fashion?
ec param inclusion in the key is perfectly legitimate usage, and should be supported, or at the very least not cause breakage of this sort.
of course just about anything can be worked-around. That's not IMO that's not a valid rationale for unnecessary breakage.
You could file a feature request with the Golang project. Support in the x509 package would be a prerequisite for any discussion on support from the Boulder side.
I'm sorry we can't support your existing workflow without modification.
That's just not true. From the very first line of the log it's clear that it's a server problem:
If it was 'clear' what the problem was, it wouldn't be a question. We'll just have to disagree on what 'clear' is.
Sounds like this (native Certbot support) is the best path forward, and the work is already in progress. Thanks for the input!
Depends on what that native certbot support will do. That's unclear,
and
has no current ETA
If you know anything about HTTP, "Response 400" is self-explanatory. So there's the possibility that it's crystal clear but still a question, in which case you shouldn't be making such definitive statements:
