Hopefully someone other has an idea. Because I first started in the pi-hole forum and checked a lot of stuff. I was hoping to get some hints WHERE to look for the root cause. Maybe the letsencrypt log might help?!
letsencrypt.log:
2020-11-12 12:01:45,553:DEBUG:certbot._internal.main:certbot version: 1.9.0
2020-11-12 12:01:45,554:DEBUG:certbot._internal.main:Arguments: ['--webroot', '--register-unsafely-without-email', '--agree-tos', '--webroot-path=/data/letsencrypt', '--staging', '-d', '<myDomain>', '--dry-run']
2020-11-12 12:01:45,555:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2020-11-12 12:01:45,613:DEBUG:certbot._internal.log:Root logging level set at 20
2020-11-12 12:01:45,614:INFO:certbot._internal.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2020-11-12 12:01:45,617:DEBUG:certbot._internal.plugins.selection:Requested authenticator webroot and installer None
2020-11-12 12:01:45,628:DEBUG:certbot._internal.plugins.selection:Single candidate plugin: * webroot
Description: Place files in webroot directory
Entry point: webroot = certbot._internal.plugins.webroot:Authenticator
Initialized: <certbot._internal.plugins.webroot.Authenticator object at 0xffff8b39bd60>
Prep: True
2020-11-12 12:01:45,630:DEBUG:certbot._internal.plugins.selection:Selected authenticator <certbot._internal.plugins.webroot.Authenticator object at 0xffff8b39bd60> and installer None
2020-11-12 12:01:45,630:INFO:certbot._internal.plugins.selection:Plugins selected: Authenticator webroot, Installer None
2020-11-12 12:01:45,640:DEBUG:certbot._internal.main:Picked account: <Account(RegistrationResource(body=Registration(key=None, contact=(), agreement=None, status=None, terms_of_service_agreed=None, only_return_existing=None, external_account_binding=None), uri='https://acme-staging-v02.api.letsencrypt.org/acme/acct/16562209', new_authzr_uri=None, terms_of_service=None), 2d714bb4994b1f3e72a4b7bfb47c7068, Meta(creation_dt=datetime.datetime(2020, 11, 11, 10, 34, 10, tzinfo=<UTC>), creation_host='8dec9dc12e75', register_to_eff=None))>
2020-11-12 12:01:45,642:DEBUG:acme.client:Sending GET request to https://acme-staging-v02.api.letsencrypt.org/directory.
2020-11-12 12:01:45,647:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): acme-staging-v02.api.letsencrypt.org:443
2020-11-12 12:01:50,657:DEBUG:certbot._internal.log:Exiting abnormally:
File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 159, in _new_conn
conn = connection.create_connection(
File "/usr/local/lib/python3.8/site-packages/urllib3/util/connection.py", line 61, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/local/lib/python3.8/socket.py", line 918, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 670, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 381, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 976, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 308, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 171, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0xffff8b392370>: Failed to establish a new connection: [Errno -3] Try again
File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 724, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.8/site-packages/urllib3/util/retry.py", line 439, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='acme-staging-v02.api.letsencrypt.org', port=443): Max retries exceeded with url: /directory (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xffff8b392370>: Failed to establish a new connection: [Errno -3] Try again'))
File "/usr/local/bin/certbot", line 11, in <module>
load_entry_point('certbot', 'console_scripts', 'certbot')()
File "/opt/certbot/src/certbot/certbot/main.py", line 15, in main
File "/opt/certbot/src/certbot/certbot/_internal/main.py", line 1362, in main
File "/opt/certbot/src/certbot/certbot/_internal/main.py", line 1226, in certonly
le_client = _init_le_client(config, auth, installer)
File "/opt/certbot/src/certbot/certbot/_internal/main.py", line 611, in _init_le_client
return client.Client(config, acc, authenticator, installer, acme=acme)
File "/opt/certbot/src/certbot/certbot/_internal/client.py", line 256, in __init__
acme = acme_from_config_key(config, self.account.key, self.account.regr)
File "/opt/certbot/src/certbot/certbot/_internal/client.py", line 43, in acme_from_config_key
return acme_client.BackwardsCompatibleClientV2(net, key, config.server)
File "/opt/certbot/src/acme/acme/client.py", line 831, in __init__
directory = messages.Directory.from_json(net.get(server).json())
File "/opt/certbot/src/acme/acme/client.py", line 1168, in get
self._send_request('GET', url, **kwargs), content_type=content_type)
File "/opt/certbot/src/acme/acme/client.py", line 1118, in _send_request
response = self.session.request(method, url, *args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 530, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 643, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='acme-staging-v02.api.letsencrypt.org', port=443): Max retries exceeded with url: /directory (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xffff8b392370>: Failed to establish a new connection: [Errno -3] Try again'))
2020-11-12 12:01:50,670:ERROR:certbot._internal.log:An unexpected error occurred:
2020-11-12 12:01:50,672:ERROR:certbot._internal.log:requests.exceptions.ConnectionError: HTTPSConnectionPool(host='acme-staging-v02.api.letsencrypt.org', port=443): Max retries exceeded with url: /directory (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xffff8b392370>: Failed to establish a new connection: [Errno -3] Try again'))
