Certbot Error 401 DNS Problem [Noob Question]
Hi folks. Please see the details as requested below. I'm quite sure that it is my fault. Unfortunately I'm quite inexperienced with Linux.
All I want to do is to generate a certificate which I want to use with Adguard Home on my Raspi. As DynDns-Service I'm using desec.io. Im using this manual for Certbot on Desec.io: TLS Certificate with Let’s Encrypt — deSEC DNS API documentation
I've installed Apache2 also and opening the default page (listening on port 81 because 80 is used by Adguard) works fine.
The credentials in .dedynauth should also be fine because I've copied them from my router settings (which should work as the url opens successfully)
Perhaps someone can give me a hint what I'm doing wrong :slight_smile:
maddino.dedyn.io
sudo certbot --manual --manual-auth-hook ./hook.sh --manual-cleanup-hook ./hook.sh --preferred-challenges dns -d "maddino.dedyn.io:81" certonly
Error output from manual-cleanup-hook command hook.sh:
curl: (22) The requested URL returned error: 401
    Domain: maddino.dedyn.io
    Type: dns
    Detail: DNS problem: NXDOMAIN looking up TXT for
    _acme-challenge.maddino.dedyn.io - check that a DNS record exists
    for this domain
Apache/2.4.38 (Raspbian)
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
Yes (for my Raspi)
No
certbot 1.14.0
Hi @maddino
a domain name has never a port, so that's always wrong.
Use
-d maddino.dedyn.io
instead.
If you use dns validation, you don't need a webserver.
But you have to create a TXT entry _acme-challenge.maddion.dedyn.io.
There - https://check-your-website.server-daten.de/?q=maddino.dedyn.io#txt - is no such TXT entry.
Compare it with https://check-your-website.server-daten.de/?q=server-daten.de#txt - Status should be green.
Hold on. Saw a typo and fixed it. Testing it again.
Hi @JuergenAuer and many thanks for your reply. I've added a entry (and removed the port again) but it doesn't seem to work so I fear I'm still doing something wrong.
dns
Your subname must be _acme-challenge.
The content must be the long string Certbot shows.
These hooks come directly from the guide which is followed, which should enable automated DNS record adding and removing. The script uses curl for communication with desec.io. I recon the hook script couldn't cope with the added :81, so I would urge you to try using the hooks again but now with just the hostname.
No reason to do manual stuff if there's a perfectly fine hook to be used :slight_smile:
@Osiris: I've tested it without the port first with the same result.
@JuergenAuer: Small problem: With all the testing I've ran into rate limits :confused: For the long string: Certbot only shows the string after aborting with the error message I've posted. So can I use this one again or is there another problem on my side?
Even so, if I were you, I'd focus on the hook script. Let's Encrypt certificates are valid for just 90 days with the recommendation of renewing the cert after 60 days. And manually doing the DNS challenge every 2 months is quite cumbersome. So if you can get the hook script to function, that would be way better.
I would recommend the following steps:
  • use the staging environment for testing! That way you won't hit rate limits when you're just testing things out...
  • add the option --debug-challenges, which pauses certbot after it has added the challenge and before it signals the validation server to try to validate the challenge. During this pause, you can manually verify if the TXT record has been added or not. Sometimes it takes a few moments for the change to propogate.
  • debug the hook.sh script. It's a rather simple script, so shouldn't be too hard with some basic bash knowledge.
And no, once a challenge has failed, you can't reuse its token.
Have to do more tries tomorrow (wife at home now :wink: ) But the problem persists that Certbot doesn't provide a token for the challenge to enter in the TXT entry. The first time I get to see this long string is when Certbot aborts with the error message I've posted above.
Is there perhaps something to prepare on my Raspi or the installed Apache?
A problem seems to be that this message:
"Setting challenge to WIUARhjNmkwo0XABnoid2oBiaeOi8W6TZqKNWEGWqE0 ...
Waiting 120s for changes be published."
Appears after Certbot has stopped. But it should appear before the 120s countdown starts. Any ideas what could be the problem?
That just depends on the options you've used to run certbot. If you use the hook script, the token gets passed on to the script.
That's the output of hook.sh after it has published the token. It could be that certbot doesn't pass through that output at the appropriate time, but only at the end. Can't reproduce that. My hook.sh that just outputs the token et c. outputs it during the run of certbot without any issue.
$ certbot_test certonly --manual --manual-auth-hook ./hook.sh --manual-cleanup-hook ./hook.sh --preferred-challenges dns -d example.org --debug-challenges
Saving debug log to .certbot_test_workspace/logs/letsencrypt.log
Requesting a certificate for example.org
dns-01 challenge for example.org
Running manual-auth-hook command: hook.sh
Output from manual-auth-hook command hook.sh:
Validation: HI3whFTHQW2OGQOPIIlgyAjg9SXspewsufbzjPmIr2Y\nToken:
Challenges loaded. Press continue to submit to CA. Pass "-v" for more info about
challenges.
Press Enter to Continue
Nothing weird there.
It seems certbot will only output the contents of such a hook in total. So if a hook does a single echo, but afterwards waits 120 seconds, certbot won't "see" the echo content until those 120 seconds have passed.
Please use --debug-challenges to check if the token is actually available at the correct hostname when certbot is paused.
This is the output when using the --debug-challenges option.
Requesting a certificate for maddino.dedyn.io
dns-01 challenge for maddino.dedyn.io
Running manual-auth-hook command: ./hook.sh
Setting challenge to xmuunTFDHMmLQUGlls2hXQhdaqm4xlY5zlBQCYCG8xI ...
Sa 10. Apr 21:53:15 CEST 2021
Token published. Returning to certbot.
Error output from manual-auth-hook command hook.sh:
challenges.
Challenge failed for domain maddino.dedyn.io
Running manual-cleanup-hook command: ./hook.sh
Output from manual-cleanup-hook command hook.sh:
Deleting challenge xmuunTFDHMmLQUGlls2hXQhdaqm4xlY5zlBQCYCG8xI ...
Token deleted. Returning to certbot.
    Detail: Incorrect TXT record "" found at
HTTP 401 is an "Unauthorized" error. Are your desec.io credentials in .dedynauth correctly configured?
DEDYN_TOKEN=here comes the token
DEDYN_NAME=maddino.dedyn.io
Nothing more in it. And the credentials itself should be correct because they obviously work in my Router settings. It seems to be a really silly mistake I'm making...
I've just set up an account on Dedyn and it works without any issue here. I've used the hook.sh from the guide you've posted:
server letsencrypt # certbot certonly --staging --manual --manual-auth-hook ./hook.sh --manual-cleanup-hook ./hook.sh --preferred-challenges dns --debug-challenges -d osirisinferi.dedyn.io
Requesting a certificate for osirisinferi.dedyn.io
dns-01 challenge for osirisinferi.dedyn.io
Setting challenge to ImIENO6aidYuqE8RyY5yuprdnbY0JpwcmRU5dm2F00M ...
Sat 10 Apr 22:24:54 CEST 2021
challenges.
Deleting challenge ImIENO6aidYuqE8RyY5yuprdnbY0JpwcmRU5dm2F00M ...
   /etc/letsencrypt/live/osirisinferi.dedyn.io/fullchain.pem
   /etc/letsencrypt/live/osirisinferi.dedyn.io/privkey.pem
   Your certificate will expire on 2021-07-09. To obtain a new or
   tweaked version of this certificate in the future, simply run
   certbot again. To non-interactively renew *all* of your
   certificates, run "certbot renew"
However, if I modify my token ever so slightly (changed a 4 into a 5):
server letsencrypt # certbot certonly --staging --manual --manual-auth-hook ./hook.sh --manual-cleanup-hook ./hook.sh --preferred-challenges dns --debug-challenges -d osirisinferi.dedyn.io --dry-run
Simulating renewal of an existing certificate for osirisinferi.dedyn.io
Setting challenge to fzaPyWXmxM2S6Ro8TYmEpU0pxeEgRDSupKmM85B-5jE ...
Sat 10 Apr 22:31:01 CEST 2021
challenges.
Challenge failed for domain osirisinferi.dedyn.io
Deleting challenge fzaPyWXmxM2S6Ro8TYmEpU0pxeEgRDSupKmM85B-5jE ...
   Domain: osirisinferi.dedyn.io
   Type:   dns
   _acme-challenge.osirisinferi.dedyn.io - check that a DNS record
   exists for this domain
Now I got exactly the same errors you got, three times in a row, 401, due to a purposely invalidated token. And if I change the 5 back into a 4 (i.e., valid token), I can successfully get a cert again.
So please double, triple and even quadruple check the validity of your token. Also note that the "Token identifier" is not the same as the actual token.
That's the stupid mistake I've mentioned. Thank you so much! I've mismatched the token identifier with the actual token. Still I'm confused why I can access the url because in my router I've added the identifier instead the actual token too.
Tank you!
Great! I was confused at first too, so easy mistake to make.
The tokens are only shown once. If one looses the token, one would need to generate a new one.
