Certbot certificate is done but https is not working
My domain is: domain.com
I ran this command: sudo certbot certificates
Found the following certs:
Certificate Name: www.domain.com
Domains: www.domain.com
Expiry Date: 2018-10-04 13:34:50+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/www.domain/fullchain.pem
Private Key Path: /etc/letsencrypt/live/www.domain.com/privkey.pem
Certificate Name: domain.com
Domains: domain.com
Expiry Date: 2018-10-04 13:34:32+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/domain.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/domain.com/privkey.pem
My web server is (include version): Apache/2.4.18
The operating system my web server runs on is (include version): Ubuntu 16.04.4 LTS (GNU/Linux 4.4.0-124-generic x86_64)
I can login to a root shell on my machine (yes or no, or I don’t know): no
Certificate is working but when try to reach www.domain.com/ it causes an error with security
This website is on wordpress, and I think there is hard redirect to https
  1. I don’t know how to turn off this redirection to even get the website
  2. https is not working
Thank you in advance!
That's because it's using the certificate for hawk-igpspunchclock.com, which is different. You'd probably be better off putting both names on a single cert, rather than on two separate certs.
Yes, one certificate with two names.
You have three certificates created today
https://transparencyreport.google.com/https/certificates?cert_search_auth=&cert_search_cert=&cert_search=include_expired:false;include_subdomains:false;domain:www.hawk-igpspunchclock.com&lu=cert_search
This
https://transparencyreport.google.com/https/certificates/ua3N5CNDpJqY1ZLW8VJwQZScM5V7Ln4Dwx0iLLiaC%2BA%3D
is correct, with two names
Now you have to install this certificate. You used certonly, so you must install the certificate manual.
If I know it correct (don’t use Apache), you have to reload / restart Apache to use these informations.
If it is wrong, then these two files are wrong.
Look in /etc/letsencrypt/live/, there should be another folder with the correct certificate. There is a command like “certbot certificates” to see which certificates exists.
This is your answer. Use these paths and filenames in your config-file.
Now your certificate is correct. You are using the new certificate with two names
DNS-Name: hawk-igpspunchclock.com
DNS-Name: www.hawk-igpspunchclock.com
But you should fix the mixed content warnings. Chrome or FireFox, then CTRL + Shift + I, then open the console. There are errors:
http://ajax.googleapis.com/ajax/libs/webfont/1.4.7/webfont.js?ver=1.4.7
http://www.hawk-igpspunchclock.com/wp-content/… [skipped]
