Certbot certificate installed but https not working
My domain is: bbgatest.com
I ran this command: https://bbgatest.com/index.php
It produced this output: I got the warning screen and a message that the certificate is only valid for ip-10-0-0-75.ec2.internal. It sounds like it isn’t finding the letsencrypt certs.
My web server is (include version): AWS Linux 2
The operating system my web server runs on is (include version): Linux2
My hosting provider, if applicable, is: AWS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): Certbot 0.31.0
the /etc/httpd/conf.d/ssl.conf file listens to 443. EC2 instance also listens to HTTPS/443. The httpd.conf file has:
<VirtualHost *.80>
DocumentRoot “/var/www/html/Clients/BBGA”
ServerName “bbgatest.com
ServerAlias “www.bbgatest.com
RewriteEngine on
RewriteCond %{SERVER_NAME} =www.bbgatest.com [OR]
RewriteCond %{SERVER_NAME} =bbgatest.com
and at the end of the file
Include /etc/httpd/conf/httpd-le-ssl.conf and that file contains:
<VirtualHost *.80:443>
SSLCertificateFile /etc/letsencrypt/live/bbgatest.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/bbgatest.com/privkey.pem
Any help you can provide in resolving is appreciated.
david
Hi @dabrjn
that's wrong. That must be
<VirtualHost *:443>
You have created one certificate:
CertSpotter-Id Issuer not before not after Domain names LE-Duplicate next LE
911719157 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-05-14 15:33:09 2019-08-12 15:33:09 bbgatest.com
1 entries duplicate nr. 1
But the certificate has only one domain name.
And your www version
bbgatest.com A 54.86.151.202 yes 1 0
AAAA yes
www.bbgatest.com A yes 11 0
AAAA yes
has no dns entry. So the alias doesn't work (but that's not an error).
But: Really "" around? Normally it's something like
ServerName bbgatest.com
ServerAlias www.bbgatest.com
Hi Juergen,
I don’t know how the 80 got in the file, but removed it and https is now working just fine.
The quotes around the server name aliases don’t make a difference. I must have picked up that habit from looking at another VirtualHost entry in years past.
Never got around to a cert for the www url. I’m not concerned about that for the time being.
I do thank you for your amazingly prompt response.
David
