Hi! I have a problem while attempting to renew the certificate.
I use: sudo ./certbot-auto renew --dry-run
And the error is:
2016-09-14 15:54:37,228:WARNING:certbot.renewal:Attempting to renew cert from /etc/letsencrypt/renewal/mydomain.it.conf produced an unexpected error: The apache plugin is not working; there may be problems with your existing configuration.
The error was: PluginError(('There has been an error in parsing the file (%s): %s', u'/etc/apache2/sites-enabled/000-default.conf', u'Syntax error'),). Skipping.
/etc/letsencrypt/live/mydomain.it/fullchain.pem (failure)
I’m on ubuntu server 14.04LTS with apache 2.
Into sites-enalbled I have 2 files:
000-default.conf
000-default-le-ssl.conf
The first is:
<VirtualHost *:80>
# specifies what hostname must appear in the request's Host: header to
#ServerName www.example.com
DocumentRoot /var/www/html
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
RewriteEngine on
RewriteCond %{SERVER_NAME} =www.mydomain.it [OR]
RewriteCond %{SERVER_NAME} =mydomain.it
RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,QSA,R=permanent]
<Directory "/var/www/html/test>
AuthType Basic
AuthName "Restricted Content"
AuthUserFile /etc/apache2/.htpasswd
Require valid-user
</Directory>
</VirtualHost>
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
The second is:
<IfModule mod_ssl.c>
<VirtualHost *:443>
# modules, e.g.
SSLCertificateFile /etc/letsencrypt/live/mydomain.it/cert.pem
SSLCertificateKeyFile /etc/letsencrypt/live/mydomain.it/privkey.pem
ServerName mydomain.it
ServerAlias www.mydomain.it
SSLCertificateChainFile /etc/letsencrypt/live/mydomain.it/chain.pem
<Directory "/var/www/html/test">
AuthType Basic
Require valid-user
</Directory>
</VirtualHost>
</IfModule>
Could you help me? Tnx!
