`--cert-path`, `--chain-path`, `--fullchain-path` seemingly not working
My domain is: darwin.pragmatika.net
sudo apt update \
&& sudo rm -rf \
/opt/eff.org/certbot/venv/ \
/opt/certbot/ \
&& sudo git clone --depth 1 https://github.com/certbot/certbot /opt/certbot/ \
&& heartbeatfqdn=$(cat /etc/fqdn) \
&& read -p 'Email address for renewal alerts (e.g. www@example.com): ' certbotemail \
&& sudo /opt/certbot/certbot-auto \
certonly \
--agree-tos \
--cert-name $heartbeatfqdn \
--cert-path /etc/certbot/live/$heartbeatfqdn/ \
--chain-path /etc/certbot/live/$heartbeatfqdn/ \
--domains $heartbeatfqdn \
--dry-run \
--email $certbotemail \
--fullchain-path /etc/certbot/live/$heartbeatfqdn/ \
--key-path /etc/certbot/live/$heartbeatfqdn/ \
--must-staple \
--no-eff-email \
--rsa-key-size 4096 \
--server https://acme-staging-v02.api.letsencrypt.org/directory \
--staple-ocsp \
--webroot \
--webroot-path /var/www/heartbeat/_well-known \
certonly \
--agree-tos \
--must-staple \
--no-eff-email \
--server https://acme-v02.api.letsencrypt.org/directory \
--staple-ocsp \
--webroot \
Creating virtual environment...
Installing Python packages...
Installation succeeded.
 - The dry run was successful.
http-01 challenge for darwin.pragmatika.net
Using the webroot path /var/www/heartbeat/_well-known for all unmatched domains.
   /etc/letsencrypt/live/darwin.pragmatika.net/fullchain.pem
   /etc/letsencrypt/live/darwin.pragmatika.net/privkey.pem
   Your cert will expire on 2020-02-02. To obtain a new or tweaked
   version of this certificate in the future, simply run certbot-auto
   again. To non-interactively renew *all* of your certificates, run
   "certbot-auto renew"
   Donating to ISRG / Let's Encrypt:   https://letsencrypt.org/donate
   Donating to EFF:                    https://eff.org/donate-le
My web server is (include version): Nginx 1.17.4 from source.
The operating system my web server runs on is (include version): Ubuntu 18.04.3 LTS
My hosting provider, if applicable, is: DigitalOcean
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.39.0
Leaf cert: 2070969775
Pre cert: 2070970711
Here’s the beef: I’m confused as to why the certificate is saved to /etc/letsencrypt/live/ when I used the --cert-path, --chain-path and --fullchain-path is set to /etc/letsencrypt/live/ in both the dry run and the live run.
This has come about as I am overhauling my build guide, replacing references to letsencrypt with certbot, to avoid any legal wrangles.
Am I doing something wrong, or have I stumbled on a bug?
Thanks in advance for any pointers.
This has come about as I am overhauling my build guide, replacing references to letsencrypt with certbot , to avoid any legal wrangles.
You shouldn't have to worry about this. Stick with the default paths that certbot provides and you should be good to go.
Thank you, @Phil – I appreciate the reassurance on the legal tip.
Is there a limitation on the paths that can be used with the --*-path flags? Do they have to contain the string letsencrypt in some form?
You can use "--config-dir /etc/certbot/".
For what it's worth, you can download the certbot-auto file by itself from https://dl.eff.org/certbot-auto. You don't need to clone a bunch of extra files from GitHub.
And there are other packages available for many OSes. The Certbot developers don't really recommend certbot-auto as the primary way to install it.
See e.g. https://certbot.eff.org/lets-encrypt/ubuntuother-other.
Thank you, @mnordhoff - I will give --config-dir a spin now. Much appreciated! I’ll also check out more efficient alternatives, thanks for the pointer.
