Cert not renewing On syno Nas
Hi all.
I’m not able to renew the certificate on my 2 Synology Nas. I get back a “operation failed, log in back and try again”. I do have the relevant ports open and the certificate was always renewing itself.
Any help will be much appreciated.
Thank you
My domain is: gabstech.it
I ran this command: N/A
It produced this output: N/A
My hosting provider, if applicable, is: OVH
I can login to a root shell on my machine (yes or no, or I don't know): don’t know
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): N/A
Hi @kadaj81
that's expected, your configuration is buggy, see gabstech.it - Make your website better - DNS, redirects, mixed content, certificates
http + non-www + /.well-known/acme-challenge/random-filename redirects to the www version, then to /.
But / doesn't have your validation file.
Remove these wrong redirects subdirectory -> /.
Hi @JuergenAuer and thank you so much for the reply.
I’m kind of a noob, but if you direct me,I’m sure i will be able to sort it out.
How do i remove the redirect? Where? In my domain? What field should i look for?
I’m very very sorry to bother you with this and probably wasting your time, but i would extremely appreciate your help.
Thank you again.
You have created that buggy configuration.
So you know what you have to change.
A noob wouldn't have such a configuration.
@JuergenAuer
If i knew it what was wrong, I would have tried to sort it out myself. I am a noob, just bought a domain on OVH, used the DDNS built in in the synology and created 2 DyN host. did not create any record or DNS zone. I did not touch that because I have no clue.
I just wanted not to use the ddns service synology.me,and make my nas more secure using a domain.
Sorry to have bothered you.
Thanks anyway.
How should that work?
Calling http://www.gabstech.it/ there is a standard OVH page, not a Synology page. So your domain provider answers, not your local Synology.
The A record of your domain name must point to your DDNS domain name (may be via CNAME, I have no idea how that works).
So you use another domain name.
Please read a lot of basics:
and
If you want to use http validation, a working port 80 / http is required. Port 6501 is unrelevant.
